I powered down pc before disconnecting new MP4 player and now it will not come up stays on Welcome and doesn't finish loading and opening up. What can I do?
  • bjsansone May 13, 2010
    Thank you very much.
    President:
  • 2,923 Answers
What happened there is that the software of the MP4 got corrupted. It seems like you unplug the MP4 without safely removing it.
The only thing that you could do is to contact the manufacturer and have them reformat the player. They will just re-install the software and upgrade the firmware.
NOTE: Please bear in mind that all the files will be deleted.
Thank you and good luck!
Posted on May 13, 2010
  • 2 more comments
    I have a CD with software is there anyway I can get the unit and my pc to talk to each other again?
  • Melvin Ramos
    Melvin Ramos May 13, 2010
    If the CD contains the current firmware, YES, you can use the CD, then connect your player to the computer.
    Refer to the user manual, because the manual will tell you where you can find the firmware in the CD. Then you have the run the firmware pointing to the MP4 player.
    Then that should do it.
    Thank you!
    Thanks. But it is in Chinese and I can only tell it is to format and don't know how to make my pc see it because right now when I plug USB in my PC doesn't see it.
  • Melvin Ramos
    If the computer can no longer see the player, I'm regretfully informing you that the problem is not ONLY the software, the internal or built-in memory is no longer working correctly as well.
    If it's only the software, the computer should be able to detect the player. And since it's not detecting it, you need to send it to the manufacturer, If possible, and they need to replace the internal memory storage, then upload the software and firmware to it.
    Sorry buddy. It also happened to me before.
    Thank you!
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with your MP4 player.
Restarting your PC resets non-functioning USB ports, which may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure you install them.
Try connecting your player to another PC to see if the new PC recognizes it.
If it does, chances are your computer does not support the hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to recognize it.
Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
Aug 25, 2013 | Intel Computers & Internet
How do I use the video converter for my mp4 player?
well first load the software, then when finished create a folder on ur hard drive where u gonna save your videos, next open the program and the are to the right of the display screen has two boxes one for input and output files. input file is the actual movie you want to format
out put file would be the folder you created next click the begin button which is the button with two arrows, one going up the next going down and wait till it finished, when finished upload the file from your output folder to the players video folder that should work
Apr 20, 2009 | Coby MP-C7085 MP3 Player
Itunes library wont all sync onto ipod
first the easy part....1800 songs we will not move this one at a time..............plug ipod to pc..open itunes....see on left hand side of screen...pc (music,photo & video folders) and under that ipod (music, photo, video folders)..ok..click on pc (music folder) all your music shows up right ok..this time click & drag the pc (music) down to the ipod music folder and release....its 1800 songs so lets wait til the ipod is finish (look at the ipod file a circular motion is happening,,,,its loading).......once finish always eject your ipod...............now find where you are storing mp3 / mp4 on your pc...once you find it ..go to top bar view then click,on view details (artist,album,type,lenght) this where it will say mp3/4/wma/wav or flac file
Feb 15, 2009 | Apple iPod MA446LL/A MP3 Player
My pc accepts mp4 hardwear momentarily then rejects it
A connection is possibly loose, seems like a hardware problem that would require service. Check the usb connector and its pins.
You have tried it on two other pcs? what was the result there did it work? If it worked on both fine, then the issue is on your computer and not on the mp4 most likely.
Please clarify.
Jan 30, 2009 | Audio Players & Recorders
Istage mp4 player
buy one that actualy works
Jun 15, 2008 | Acer MF35 MP3 Player
Can you help me?
well it sounds like your system may need to be reset, is it new or have you had it for a while? i would start by going to the website and see if there are any forums or directions you can look at to fix it.. if it's new, i would definitely contact that manufacturer or go to their site for some support, maybe even online.. i hope this helps..d
Feb 18, 2008 | Apple iPod MA446LL/A MP3 Player
Manual for infitek mp3/mp4
Problem: Infitek MP4 player is recognized by Vista and Windows XP but when you try to put files on it, error pops up.
Solution: The MP4 needs to be reformatted to FAT32 file system, here is howto do it:
1) Connect USB cable to PC
2) Connect Infitek to cable.
3) An AutoPlay window will pop up on your PC. Select "Open folders to view files using Windows Explorer"
4) On the left of the explorer window the following will be seen "Removable Disk (?:)" (? can be any letter in the alphabet, most likely E-K)
5) Right click on "Removable Disk (?:)" with your mouse and select "Format"
6) "Format Removable Disk (?:)" window will appear, select FAT32 from the FIle system Combo box and select Quick Format from the Format options and click on START
You may need to format the MP4 more than once, it did not work for mr the first time.
7) After you receive a message, Format completed successfully you can drag and drop any files to the "Removable Disk (?:)" which is the MP4 player storage area.
8) Disconnect the cable, turn on the MP4, if at main menu use the >>| key to get to the Music, Click MENU key to get to the first song, click >|| to play song.
I used .WMA files (Windows Media Player) songs. They seemed to work ok
Oct 07, 2007 | Coby MP-610 MP3 Player
Can't disconnect from PC
No. Windows is just weird that way...
Sep 26, 2006 | Epson PhotoFine P-2000 Digital Media...
27 people viewed this question
 Grubhead
Grubhead
