Question about Samsung RS2630WW Side by Side Refrigerator
I want to know if you can de-ice the freezer without turning the refrigerator section off. There's ice buildup in the freezer, obstructing the door. I want to de-ice it but don't want to turn off the fridge section and ruin the refrigerated food. I've turned the freezer to it's weakest freeze setting & opened the door wide. But the freeze element is keeping it too cold for the ice to melt. There's only one power chord for both sides of the fridge.
    New Friend:
  • 48 Answers
Boil kettle and place boiled water in a bowl and place in freezer. Repeat until freezer defrosted
Posted on Jun 20, 2017
2 Suggested Answers
SOURCE: de icing the freezer in a Samsung SW 2630WW
Take all of the shelves out of the freezer side. Take to Philips screws for backing and 4 philips screws from vent cover just above cover. unplug, Use a hair blow dryer and melt it. Put it back together and there you go. Whole operation from start to finish is about 15 minutes.
Posted on May 20, 2010
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
A 11 year old whirlpool fridge.. freezer working but not the fridge.. water dripping out from the shaft between freezer to fridge
HI, sounds like you have 2 problems. First of all, your drain pan in the freezer is clogged and will need to be cleaned out, second: this ice has caused an air flow restriction to the refer section. When you clear out all the ice, look for obstruction that you prevent clean air flow to the refer section. This should solve the problem.
You may have to remove all the food from the freezer, remove shelves and rear wall to clear all the ice. Failure to remove all the ice can prevent air from circulating from section to section. I would not suggest in using a hair dryer, too much heat in the wrong place can cause damage to the liner in the form of warping.
Turn off the unit while doing this de-icing, this will help greatly.
Good Luck
Aug 14, 2011 | Whirlpool Refrigerators
De icing the freezer in a Samsung SW 2630WW
May 13, 2010 | Samsung RS2630WW Side by Side Refrigerator
Ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Nov 21, 2009 | Gladiator GAFZ21XXMK Bottom Freezer...
Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Nov 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator side of my side by side to warm
Check the back wall of the freezer section for signs of frost buildup. Your problem could be caused by a frozen evaporator coil in the freezer section. After making your check come back and give the model number of your Maytag .
Jul 03, 2008 | Maytag Refrigerators
Right side of refrigerator not cooling; frezzer working great
Ice build up on back wall could be defrost thermostat or faulty defrost heater
Mar 21, 2008 | GE GSS20IEM Side by Side Refrigerator
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Samsung RS2630WW Side by Side Refrigerator Logo
57 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
