Question about Singer QuantumLock 14T948DS Mechanical Sewing Machine
How do I change a needle on my Singer serger 14t948ds. The instructions and drawings are really bad.There is a screw on the left and two screws on the right, one above the other. Which would I loosen. Thank you very much. Joyce
  • 255 Answers
SOURCE: inserting needle on old singer machine
Hi Terry--
If your machine is 40-50 years old, it might be a Singer Featherweight portable. (If it is, you have one of the very best machines ever made!) On the Featherweights, the flat of the needle faces left (and the needle is threaded from right to left). The bobbin goes in a bobbin case; you'll see a small notch when you look down on the bobbin in the case. That's where the thread goes. I'll email you direct with more information.
Lookingpast
Posted on Jan 11, 2008
bibleman01
  • 334 Answers
SOURCE: I lost the needle screw for Babylock EA 605 Serger
Almost all needle screws are the same size. Just check your yellow pages for sewing machine repair shops near by.Most of them would have it
Greg
Posted on Dec 05, 2008
Michaelle
  • 65 Answers
SOURCE: Replacing needle on Elna Pro 905 DCX serger
Try and loosen the screw, and use a magnet to pullout the broken piece. It likely slightly bent in there so you may need a pair of tweezers as well
Posted on Jan 24, 2009
Mimito7
  • 128 Answers
SOURCE: needle for a singer tiny serger
Hi, ALthough it is called a "Tiny Serger", it will still take regular singer serger needles.
Posted on Apr 24, 2009
  • 3 Answers
SOURCE: I have a Singer 6233 and the drop in bobbin is too
I went online and found a diagram that showed where the screw was to loosen or tighten the drop in bobbin thread (it faces the front) but it couldn't be seen until I slid the sliding door totally off. I had to use a flashlight and very small screwdriver and was able to loosen the screw a tiny bit and it solved my problem. I've been sewing for over 40 years and didn't know how to adjust the tension on a drop in bobbin until now. You learn something new everyday!
Posted on Dec 21, 2009
I can't move the needle clamp to change the needle on new Singer 2250 Traditional. Can you help?
Here's the manual with the instructions:
SINGER 2250 Instruction Manual Inserting And Changing Needles
The screw that holds the needle in place also has a slot where a screwdriver can be used to apply extra pressure.
May 07, 2017 | Singer Sewing Machines
I changed broken needle but accidently both of them came out now the left needle does not stay in
Assuming this is a serger? Is there only one needle set-screw on the machine or one set-screw for each needle? If there are two set-screws, then you may have accidentally lost the set-screw for the other needle. If there is only one set-screw, both needles will need to be installed at the same time, hold them all the way up and simultaneously tighten the set-screw.
How To Change The Needle on the Brother Serger 1034d 4 Thread 2 Needle... (this machine has only one set-screw for both needles)
Some other machines, ie Bernina, have a set-screw for each needle.
Dec 09, 2016 | Sewing Machines
Can I replace the plate needle on the singer profinish serger myself
Laura's Blog: Do it yourself serger repair - How to adjust ...
bangerlm.blogspot.com/2007/.../do-it-yourself-serger-repair-how-to.htm...
Jan 30, 2007 - So I recently did something awful to my serger and the needle broke, the ... Plus it isn't really generic, it is basically some notes for some various olderSinger sergers. ... There were two screws on the bottom plate, plus 4 screws in each of ... If you thread the machine and you can't get the lower looper thread ...
How to fix timing on serger - YouTube
? 4:36
https://www.youtube.com/watch?v=BT6kiYyG2bw
Jul 21, 2013 - Uploaded by Jasmine Harris
Up and close detailed view of how to fix timing on your sergermachine ... looper and lower looper should be when the needle is up or down. .... way I can ever take it into the shop, so unless Ican fix it myself I'm out of luck. .... How to fix the upper looper timing on a Singer serger/overlocker - Duration: 11:02.
[PDF]Singer 14CG754 Serger Commercial Grade Manual.
www.sewingmachinesplus.com/media/.../singer/.../Manual_14CG754.pdf
Jan 10, 2016 | Singer Sewing Machines
My left needle keeps breaking
Could be: Wrong needle size for fabric: The presser foot is not the correct one for the type of stitch you want to sew: The needle clamp screw is loose. Hope this helps.
Jun 27, 2015 | Singer 14SH654
Need instruction manual for Singer 14U32 Serger
On the singer website on the home page look for
Instruction manuals at the bottom of the page-click on it
Put in your model number & click search
Jan 20, 2011 | Singer QuantumLock 14T948DS Mechanical...
I have an older model singer serger Model 14U85 Ultralock. The chainstitch needle set screw hole has stripped. Can that whole piece be replaced on my machine?
Call Singer at 1-800-4singer and see if they can sell you that part. I am sure that they can because they do not change the parts that much on the machines. Good luck
Jan 17, 2011 | Singer Sewing Machines
Singer QuantumLock 14T948DS Mechanical Sewing Machine Logo
568 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
