Question about Robotoolz 20x Builder's Level Plumb Bob Case Rt221020
Builders level Model RT-2210-20. Lost part of focusing knob
Have only one end knob and dowel that goes from end to end. Anyone know where to order parts?
Who manufactures the volume knobs for T250 MOTOROLA RADIO?
Giant International. Best of luck. I have never been able to order knobs. Be prepared to make something. I used wooden dowel plugs, drilled into the center and stuck them on with loc tite.
Aug 31, 2016 | Motorola Radio Communications
Can i hard wire my rt 2770 rca home theater subwoofer to my receiver lost white plug that plugs into receiver and can't find a new one?
I have one if you still need it. Hooked my sub up to a different receiver and cut that end off to hard wire it. It has about a foot of wire and the white plug on the end that goes into the receiver.
May 11, 2012 | RCA home theater system RT2770 User Manual
How do you remove the starter out of a 2003 ford focus?
Removal
1. Disconnect the car's negative battery cable.
2. Raise the car's front end with its floor jack and support it on axle stands; make sure you set the parking brake first.
3. Disconnect the air cleaner's outlet tube from the throttle body if your model has an SPI engine; loosen the hose clamp with pliers.
4. Unbolt and disconnect the power-steering pump using your wrench and set the pump aside. Do not disconnect or stretch the pump's lines. This should only be needed if your Focus has a 2.3 liter engine.
5. Unscrew the starter motor's mounting bolts using the wrench and then pull the motor off the dowel sticks on the transmission housing; you might need to angle the motor to remove it. Unscrew the nuts and disconnect the motor's wiring.
Installation
1. Connect the wiring and nuts to the replacement starter motor and slide it onto the dowel sticks, then tighten the mounting bolts with the wrench.
2. Reconnect all components that were disconnected--bolt the power-steering pump in place and connect the air cleaner outlet tube using its clamp.
3. Lower the car off the axle stands and reconnect the battery cable
Mar 02, 2011 | 2003 Ford Focus
Front forks
Remove the spring caps but leave the springs in. Compress the front suspension fully. Find a rod or wood dowel that will slide easily down the middle of the spring. Mark it 6 - 7 inches from the end. Insert the rod/dowel to the mark. The bottom of the stick is the proper level of fluid, in most cases. Please buy a service manual!
Apr 10, 2010 | 2003 Honda CRF 230 F
Sony rear projection tv model KP-53V15 turns on, have sound but no picture, after a while, picture comes on, but later goes out again, picture keeps coming and going. Where do I start looking?
Adjust Screen Volts (G2) of all 3 picture tubes and screen volt control knobs are on focus block located under speaker grills at front of TV.
Remove speaker front grille of TV, look for focus block that has 6 control knobs, 3 knobs are for focus and 3 for screen volts, increase volts by turning little bit control knobs of screen volts and this will solve your problem.
Nov 02, 2009 | Sony Televison & Video
How do I focus on the moon. Model 1400150. I have been gifted this telescope. Tried to focus on moon. Dont know how. Took big cap off end. Looked throughscope on top of large cylinder. Tried to focus...
first, use the lowest power eyepiece, that's the one with the high number on it with 'mm' after the number.
for a refractor telescope (uses lenses), you might have to add a diagnal lens (either 45 degree or 90 degree, whichever one you have) to focus on an object.
attach it in this order:
low power eyepiece-->diagnal lens-->main telescope
for a reflector telescope (uses mirrors, a telescope with a big tube with a mirror at the bottom and a focusing knob on one side of the tube). the open part of the tube points to your target.
hope this helps :D
Aug 07, 2009 | Celestron Optics
Stage slowly falls causing unfocus
Try holding the Right knob so it does not move, whilst firmly moving the Left knob towards you (clockwise), this is the adjusting method used on Zeiss Jena 1960's High End microscopes, e.g Eduaval & Ergaval.
Good luck,
Alan Mowle
Mar 05, 2009 | Science & Laboratory
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
Focus knob screw
Not enough information to answer question.
Jun 04, 2008 | Optics
Robotoolz 20x Builder's Level Plumb Bob Case Rt221020 Logo
52 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Jim Parker
Jim Parker
 Mikey
Mikey
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
