Question about Canon PIXMA MP150 All-In-One InkJet Printer
What and where is an overflow tank and how do i fix it
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 74 Answers
The overflow tank is inside the printer and to be clean you have to take it to a specialist. However you can reset the waste ink tank counter like this:
MP150 Reset
Following is the procedure to reset the wate ink counter for the Canon Pixma MP150
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Posted on May 13, 2010
03 dodge intrepid I keep having coolant leaks.i fix one leak and I get another... new overflow tank, first...then bleeder valve cracks...fixed... then radiator...fixed..now im leaking fluid from bottom of...
You may have a blown head gasket thatis pressurizing the coolant system-pull radiator cap off and put a pressure gauge on it and see if pressure goes above 17.5lbs-cheers Denny
Oct 09, 2013 | 2002 Dodge Intrepid
2000 ford windstar overflow tank has a crack in it how do I fix it
remove bolts and a hose with a clamp then find junk yard and replace it should only cost 10 dollars and 30 minutes of your time .
Feb 19, 2012 | 2000 Ford Windstar
Kohler Highline Class V tech toilet. Bowl does not fill. Why? What can I do to fix it?
Check tank for fill line running from fill valve to overflow tube. It will be a 1/4 " line that allows the tank and bowl to fill. It should be connected from fill valve and connected at the top of overflow by a clip or hanger.
Check out the water level in tank to make sure it is filling to line on overflow or within 5/8" to top of overflow pipe.
Feb 06, 2010 | Kohler - Toilet - Two-piece - Highline -...
Overflow tank appears to be leaking as I find fluid on the ground. the truck doesn't overheat or warm hot. how difficult is it to remove the overflow tank?
Before removing the overflow tank check:-
1) the pressure cap is of correct specification and serviceable,
2) the overflow tank is not over-filled- space most be allowed for normal expansion of coolant.
The overflow tank should not be difficult to remove if it is necessary.
Nov 13, 2009 | 2003 Ford Ranger Regular Cab
Low Coolant light
Sounds like your sensor unit in your coolant overflow tank. Like nearly everything man made that floats, they will eventually leak (become water logged). This is a relatively cheap fix, as long as the light is coming on and the coolant level in the overflow tank is between the MIN and MAX lines in the overflow tank. This means that the float in there is dropping below the actual fluid level (watter logged) and you need to get a replacement sensor unit (aka sending unit) for the overflow tank.
Otherwise, if the coolant level in the overflow tank IS BELOW the MIN level line on the tank, then you are losing coolant somewhere and that is when things start to get expensive (might be a radiator problem, head gasket, cylinder head, heater core, etc).
Jul 19, 2009 | 1997 Pontiac Grand Prix
Low coolant light is on put there is plenty of coolant and car is staying cool according to gauge inside.
Hi..my name is Keith..i have a 1997 Ford Taurus..and i also have a low coolant light on..but i have a small hole in my overflow tank and it wont hold fluid..but my car dont overheat either..just the light is annoying and i'll get around to fixing it oneday..so...the only things i can think of that has turned your light on is....1..that you need to put coolant in the overflow tank...2..you have a hole in your overflow tank(like me) or 3...the quanity sensor in you overflow tank is bad..so i hope this has helped
Jul 04, 2009 | 1999 Ford Taurus
Check gauges indicator light comes on
Look for a crack in the overflow tank. It will be somewhere along the bottom if there is one. The other possibility is that the hose to the tank is leaky and/or the lid to the overflow tank is loose and you are suffering from evaporation. Once you fix the leak, refill with a mix of 50% anti-freeze and water.
Dec 28, 2008 | 2000 Jeep Grand Cherokee
Canon PIXMA MP150 All-In-One InkJet Printer Logo
117 people viewed this question
old marine
old marine
