How to tell if Washing Machine Water Pump is Broke???
I have a Kenmore top loading washing machine that is leaking water. I have been told that it is probably the water pump (part # 3363394) and that I should replace it. My question is how can I be sure that it is the water pump before I buy a new one that can not be returned. I took the water pump out and am wondering just how easily or not it should turn?? Should this part be able to spin easily or should it be tight. Can I even tell by this if it is for sure broken? Any advice would be greatly appreciated. Thank you!
  • TaylorAnn May 14, 2010
    THANK YOU!!
  • Washing Mach... Master
  • 8,220 Answers
This guy made a home movie
SERVICE MANUAL and more HERE
Posted on May 13, 2010
Testimonial: "Thank you so much! My washer is fixed."
2 Suggested Answers
dr appliance
  • 266 Answers
SOURCE: I have a Kenmore top loading washing machine that
take one of the pump to motor clips with the t end of it insert into it turn does it f turn ...if it really hard then replace it otherwise ..... look inside port"s for foreing debris and the replace lid switch
Posted on Feb 03, 2011
Leaking washing machine
The leak is probally coming from the drain pump itself or the discharge hose onnected to the pump. This is easy to check and replace. This video should help
http://appliancehelponline.com/topdirectdrivevideo.html
http://appliancehelponline.com/toploadcabinet.html
Jun 04, 2010 | Kenmore 22622 Top Load Washer
Machine is leaking water from somewhere?
there is a seal between the drum and transmission,more than likely thats where its leaking. also check your fill hoses and valve
Jan 09, 2010 | Kenmore 22422 Top Load Washer
Washer leaks water from bottom
Water pump or hose came off or broke but i bet its the water pump
Feb 06, 2009 | Kenmore 23822 Top Load Washer
Kenmore elite, water leak
Check the mix valve area where the water enters the machine, during the fill.
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 - water leak not from hoses - could it be the pump?
Hi Gleen you probably need to remove the rear cover to expose the in side of machine.
Note if you could post a model number I could tell you for sure what would be the best way get to the pump.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Water is coming out of the bottom of the washing machine
Tip the machine back and remove the 2 clips holding on the drain pump. Remove the hoses. Then turn the pump over to where the motor shaft enters it. There will be signs of water leaking out of the pump. Your local parts store will have the pump instock.
Nov 22, 2008 | Kenmore 22422 Top Load Washer
Washing machine leakes some where frome the bottom of washer
It sounds like you pump is leaking. This happens most of the time( if its a kenmore or whilpool)lean your washer back and then you will see the pump on the end of the motor. it is held on by 2 clips and then you can take it off (after pulling iff the 2 water hoses) Look at where the motor shaft goes onto the pump if its leaking there will be a water streak. Replace the pump... leak is fixed
Oct 28, 2008 | Kenmore 23822 Top Load Washer
Kenmore washer top load heavy duty 80 fluid leaking
It's rusty Water probably the water pump housing is cracked might be replaceable need to take a look at it or call Kenmore for the part
Apr 13, 2008 | Kenmore 24032\24036 Top Load Washer
Leaking
check your water valve at back and your water connection.if there o k it probably is your pump.
Nov 12, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
953 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
