Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
I have a pd42s20w and lighting hit my house now my hd ports don't work someone told me it may be my control turner but i can't find that part or remote for it
    Top Expert:
  • Daewoo Master
  • 14,553 Answers
Lightening can damage equipment in two ways.
A nearby hit can travel in via the power lines or via the signal inputs equipment is connected to.
If via the power lines you will have dead units. I would suggest it came via the the signal path. Static electricity can do odd things. Lots of parts in the set and whatever is connected to it can be damaged as they are static sensitive and most surge protectors do not work fast enough to prevent this.
To determine where the problem is find some other piece of equipment that you connect to the HD input and see if it works---Lots of Blue Ray and other items are able to do this.
If you have the same problem with an external unit that is HD hooked up the trouble is in the set. The most likely source would be the "main" board which processes all signal in the set and is usually connected to all the inputs directly.
The question here is if this is the case they only sell boards and Daewoo is not a company that likes to sell boards.
Another possible way to pursue this is if you have homeowner or renters insurance see if you are covered for this kind of damage.
Let me know what you find and remember I am here to help you.
SD TECH
Posted on May 13, 2010
Panasonic Plasma TH-42PZ80U HDMI do not work after lightning storm
I don't have a solution, unfortunately, but your problem is nearly identical to mine. It even seems to have happened on the same date (7/27/12)! Do you live near Dener by chance? Anyway, we have Direct Tv, and ended up with 2 fried HD DVR boxes and 2 TVs on which the HDMI connections don't work after lightning hit close to our house on 7/27. Those boxes were replaced, as was part of the Direct TV dish. The only difference is, whereas on one TV component connections (red/white/yellow cables) allowed the TV to work normally, on the other (my 50 inch Panasonic Plasma TCP50S30) even the red/white/yellow cables did not work. Now I'm scouting the net for tips on what else to try before I possibly have the Panasonic looked at, which I am hedging on doing since I got it for only $600 new in the first place. Have you found out anything else since you posted this? Good luck to you...
Jul 27, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Brake light stays on a hd 2003 fxsts Problem
Usually when the brake light stays on it's because the front brake light switch is broken. You can try loosening the front master cylinder clamp and slide it back against the right handlebar switch housing. If that doesn't extinguish the brake light, the switch is probably broken. You'll have to go inside the right handlebar switch housing to replace the switch. Loosen the adjustment on the throttle and idle cables, remove the two screws that holds the switch housing halves together and separate the halves. Take the cables loose from the throttle sleeve, don't lose the ferrules on the ends of the cables. Lower the lower half of the switch housing and you'll see the switch in the front of it. You'll probably have to desolder the wires, replace the switch, the resolder the wires to the new switch. Make sure you get the throttle assembly back together correctly and that it works properly. Don't pinch any wires when putting the switch housing back together
Good Luck
Steve
Jun 03, 2011 | Harley Davidson FXSTS Springer Softail...
Location of data port.
u dont have an obdll system u have an obd which is a 12 pin port under dash by steering column
Feb 13, 2010 | 1991 Cadillac DeVille
Explaihow to wire a turner +3 mic to a president washington base
Here you go 1/shield 2/white 3/black 4/red . Good luck......Dan
Apr 28, 2009 | Magnum DeltaForce CB Radio
HDTV Turner
If your set has HD on it means set is HD Ready and you do not need Converter Box even if your only signal is coming from an antenna. Either a TV has HD or it Does not! And NO you cannot buy Parts to make your set HD.
Dec 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Aspire 5100
go to control panel, administrative tools.. event viewer
Jul 06, 2008 | Acer Aspire 5100 Notebook
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
125 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
