D-104 desk mic show good modulation on am but poor modulation on ssb compared to the factor hand mic. Has new battery, using it on a cobra 2000 base radio
  • Andy Beck May 13, 2010
    Thank you I try that and get back with you thanks again
    Top Expert:
  • 14,553 Answers
First: I am a old time CB operator and have repaired lots of the 2000 GTLS.
There are several versions as you know of the D-104 but if ok on AM but SSB is poor, it is more likely a problem with the radio.
What happens often in this radio is someone "removes the mod limiter" and there are several ways to do this. If done by removing the WRONG transistor or part, AM will be fine but SSB will be poor or distorted and may be described as CLIPPING etc.
The simple way to determine if the ALC has been defeated is to locate the VR (control) on the main board and turn it full left. If the radio still modulates on SSB the wrong modification was done.
It will work with certain microphones but when one with enough audio is connected it will clip and distort the audio.
The overall modulation is controlled by another VR marked AMC (auto modulation control).
You can attempt to connect the d=104 to another radio and see what happens---any of the older 148 radios should work with it.
Let me know what you find if you do what I suggest and I am here to help if you have questions.
73's......
SD TECH
Posted on May 13, 2010
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
TX oscillation
Make sure your boots are switched off and run the radio off a good car battery before you start looking for problems inside the radio. This problem may clear or change characteristics when the supply is changed.
Nov 28, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 2000 with a d 104 mic and a palomor tx100 bi linear amp...how can if possible make the amp key up with less than one watt on the ssb side..Radio has a 4 watt dead key on am and i have ajusted the...
Hi, my name is John. Adjust the radio to key 1 watt, then switch to SSB on radio,then switch to SSB on amp, key down and adjust to 1 watt on amp. enjoy !!!!!! ...hope this was very helpful....
Aug 31, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
I have a new cobra 148 with ssb, about 6 months old, while i was away there was a storm, now the radio doesnt work , recieve or transmit, i also have a cobra 29 ltd that wont transmit but it will recieve....
make sure the mic is good. If for some reason the mic went bad, it will not receive or transmit.
As for the one with no receive, it most likely needs a new final.
If lightning hit your antron, it would be in pieces.
Aug 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 132 recieves good poor send
i would take it in and get a new diamond thats what it sounds like to me..
Dec 02, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
President mckinly ssb/am model with mb8719 pll chip.
It looks like you had some loose connections in that CB. you may want to also check for other cold solder joints throughout the units and touch them up with some solder. Might I suggest you use a desoldering tool and then just add new solder to the connection.
Jul 31, 2007 | Cobra 19 DX III 40-Channels Base CB Radio
27 people viewed this question
 Grubhead
Grubhead
