Question about DB Drive SP10D.1 Car Subwoofer
I have a hole in my brand new db drive sub cone what do I do?
  • 86 Answers
Take it to the store from where you purchased this system and they should refund your money or exchange the item.
Posted on May 30, 2010
I have a set of technics SB-5000a speakers. one of them the 10" sub is blown. there is no resistance accross it. the cone is in good shape so i think it is the driver. normally you can unscrew the...
if there's NO resistance, see if the lead running to the cone (coil) has broken.
If so, you might be able to solder it back on and save the speaker.
Sometimes they separate at the terminals, sometimes at the cone.
If it separated at the cone, you may need to peel back a bit of paper to get to the wire underneath, and scrape the enamel coating off the wire so you can solder to it.
Otherwise, it's off to your local audio mart to buy a 10" whoofer at the same or higher wattage and same impedance. Take the old one with you to make sure the screw holes align too! (although that's not 100% essential as you can always drill new pilot holes wherever the screw holes aare....unless the screw holes have a metal insert)
If you did have to peel back some paper to do the repair, reinforce the torn area with toilet paper and fingernail polish. Use several layers as you don't want the movement of the whoofer to rip apart your solder joint or any more of the cone.
Mar 15, 2011 | Audio Players & Recorders
When i first bought my alpine type r 12's they were perfect bass really loud but now they aren't as loud i think the cone inside messed up
If the cone messed up there would be a lot of rattling. Most likely the subs have just gotten broken in and won't sound as loud as brand new. Over time and with use a subwoofer magnet will start to weaken. When the magnet weakens it won't hit as hard anymore.
Aug 15, 2010 | Car Audio & Video
How much airspace do i need for my subwoofer and should i port the box
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 11 inches x 11 inches x 11 inches. Hope this helps
Jun 26, 2010 | DB Drive SP10.1 Car Subwoofer
I have a 12 inch ORION HCCA dvc, 4ohm sub. My
Halving the impedance will draw twice the current. You could technically get a 3 Db more power since the peak voltage will remain the same. BUT if the magnet structure is not intended to use that cone design, the magnet difference MAY not give you 2 ohms.
In fact, if the designed magnetic flux were smaller, you could wind up with a 1 ohm speaker.
trying to get that much power is really kind of silly as even 50 watts with efficient speakers will exceed safe levels of sound that will not cause damage to your ears.
As you push an amp up in power, usually distortion will increase as well.
Oct 26, 2009 | Orion HCCA 12D Car Speaker
Db drive vs kicker
The Kickers are the way to go here- they move more air because naturally a 15 inch square has more area than a 15 inch circle- thus more air moved =greater spl =LOUDER. The only thing that might get some equality between the two is if the db drive round sub has a far greater xmax that is the linear movement of the cone from start to full excursion-IF the db drive has drastically larger xmax than it could possibly outperform the L7 because of greater cone excursion which also =more air moved=louder---- haha thats a tricky one but ya got me wondering too so let me know what you find out please-Ive always been a kicker fanatic so im probably biased towards their products-never heard nothing bad about db drive though either im in salt lake city i dont know of anywhere out here that even carries their products so i have nothing to reference by except kicker L7's kick asssssssssss
May 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
How should I wire up this amp and sub
The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
Jun 10, 2007 | Kole audio Q2-480 Car Audio Amplifier
DB Drive SP10D.1 Car Subwoofer Logo
Top DB Drive Car Audio & Video Experts
Professor_V
Professor_V
Tom Chichester
Are you a DB Drive Car Audio and Video Expert? Answer questions, earn points and help others
