Equium M40X freezes
Equium M40X-149 freezes suddenly,some times just after switching on,some times after few minutes working.And I can't do nothing,just switch off using switch on/off button.
    President:
  • 2,351 Answers
Hi, it seems your experiencing a overheat issue. At least one fan inside your PC has stopped working. The PC monitors internal heat, when the PC reaches a certain temperature it will shut down & or freeze. Chances are it's the CPU fan.
Link for your model no#
http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/jsp/SUPPORTSECTION/discontinuedProductPage.do?service=UK&DISC_MODEL=0&highlightOption=5420&com.broadvision.session.new=Yes&PRODUCT_ID=104113
Mike
Posted on Mar 29, 2008
Where is the memory card for Toshiba Equium M40x-149 model
The memory modules are under a screwed panel on the bottom of the laptop.
Click on this link for a picture of this memory slot.
http://img185.imageshack.us/my.php?image=ramshotzs5.jpg
Jul 30, 2009 | Toshiba Computers & Internet
I ve formated my Toshiba Equium M40X-103 and on start up i can't see the display. i'm guessing i need to download some drivers but how can i instal without any display?
Attach an external monitor. Even without drivers the lcd should at least lite up with post info If in hibernate mode holding down backspace when power up sometimes works. My guess is if the cover open switch is ok and you still see nothing it may be the lcd inverter or the fl tube, Also look very close at the screen from a slight angle if you see stuff it is one of the above problems gl
Jul 08, 2009 | Computers & Internet
How to remove keyboard of how to remove the cover of a toshiba equium m40x 148 laptop
try this link
http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
good luck !
Jul 02, 2009 | Computers & Internet
Toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
May 18, 2009 | Toshiba A70-S256 Notebook
Need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
M40x sometimes freez on logo
Sometimes viruses can trigger slow start ups. Try running your virus scan. also, you should make sure that your memory is working correctly. When you have a memory stick that has failed, its hard to tell if you have over 2 gigs of mem installed but, when you start it up, it will struggle during the process.
Jan 28, 2009 | Toshiba Satellite M45-S165 Notebook
Non-functioning keys toshiba equium keyboard m40x 149
Have you tried connecting a regular desktop keyboard to your laptop? If so, does the same thing happen?
Keyboards do develop problems, and can usually be fixed by replacing the keyboard. It's not necessarily a virus (actually highly unlikely).
Aug 05, 2008 | Computers & Internet
My Toshiba Equium M40X-189 DVD is Locked
PLEASE LET ME KNOW IS IT NOT OPENING YOUR DRIVE TRAY OR THE CONTENT IS LOCKED LIKE REGIN SETTING>>>
Jun 01, 2008 | Computers & Internet
Equium M40X gets overheated
this is a laptop computer?
THis is probably a simple heating problem. if it is, you'll have to replace or otherwise repair the heatsink, and maybe the CPU as well.
In general, if this is still under warranty, your best bet is probably to just return it to toshiba for repair/replacement.
I would NOT reccomend opening the case on an in-warranty laptop.
However, in case this ISN'T a heating problem, or if you need a temporary workaround... these ideas MIGHT work. they won't be permanent solutions, though.
1. try setting your bios, and your windows settings, to the options that use the least power.  less power = less heat.
2. If you deliberatly overclocked your cpu at some point, reset it to normal speed. or even less-then-normal speed.
3.  are you certain this isn't just a power problem, or a corrupt operating system?  you might want to try reinstalling the os, and running the computer from an AC outlet, maybe even with the battery removed
Mar 29, 2008 | Computers & Internet
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
