Question about Car Audio & Video
How do i detach the face for a dual car stereo model XDMA7715
    President:
  • 2,317 Answers
You can go here and download the owners manual for your stereo:
http://www.crutchfield.com/S-DSkvoEYAB61/p_070XDMA771/Dual-XDMA7715.html
Posted on May 13, 2010
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
There is a dvd stuck in the player. The dvd loads and plays just fine but won't come out after pressing the eject button.
DOES YOUR STEREO HAVE A DETACHABLE FACE??
IF IT DOES, THEN YOUR LUCKY, CUZ ALL YOU NEED TO DO IS DETACH THE WHOLE THING OFF. IT HAS A RESET BUTTON BEHIND THE FACE. PRESS IT WITH A SHARP TIP AND VOILA.
NOW IF YOU HAVE THE KIND OF STEREO THAT CAR MANUFACTURERS PLACE IN VEHICLES THEN JUST DRIVE TO YOUR LOCAL AGENCY AND PAY THE FEE.
GOOD LUCK
Jun 22, 2010 | Cars & Trucks
How to remove the stereo from the sleeve or unlock the stereo from thesleeve
you will need to use and thin but stiff piece of metal. You will need to remove the bezel around the radio, If the radio is a detachable face, you will also have to detach the face. Insert the the pieces of metal, about 3 inches long, on the sides of the radio. You will only have about a half inch sticking out. You will need to then carefully pry the radio out towards you. It will come out slowly and carefully. Good Luck.
May 10, 2010 | Clarion ARX7370
Just installed an XDM7615 Dual stereo and the face plate won't detach. Can anyone help? The manual says there is a button behind the face when it's in the 'eject' position but pushing this button does...
There are 2 very small screws on the back of the face plate that need to be removed. Once these are removed, you may then remove the face plate.
Feb 10, 2010 | Car Audio & Video
Tring to install blutooth to my xdma7715 dual cd player
The Dual XDMA7715 unit does require a separate module called the Dual BTM60, as technically the XDMA7715 is a "Bluetooth Ready" cd player.
Assuming you have bought this module, the next thing you need to do is 'Pair it" with your mobile device, which I will assume is your cell phone. This keeps it from connecting with other people's cell phones as they drive by your car.
Before you begin, you need to prepare your phone for paring. Check your cell phone's users manual if these instructions don't apply, but generally this means you find the Bluetooth menu on your phone, turn bluetooth on, and make the phone 'visible' which means your stereo will be able to see it in order to pair up with it. Usually, turning visibility on only lasts for about 30 seconds, so you may have to try this more than once to get the timing done right. Once paired, you won't need to turn the phones visibility on again until the next time you pair a device.
Now that your cell phone is ready to pair with the stereo,
1) Press the Phone symbol on the cd player or the BTM60, pr press MODE until 'DUAL_BTM60" is displayed.
2) Press and hold the phone symbol on the cd player or the BTM60 for 5 seconds, until "PAIRING" is displayed. The Bluetooth icon will flash every second. The Cd player will broadcast its "availability" for 60 seconds.
3) Complete the pairing from the Bluetooth menu of your cellphone by selecting "Search for new devices". When they find each other, the Bluetooth icon will illuminate solid, and your phone will say it has found device "DUAL_BTM60", and ask you for a password to pair it.
The BTM60 device name is "DUAL_BTM60".
The password you enter into your phone to accept the pairing is "1234"
Now that the devices are paired, you should be able to make calls handsfree, and play music stored on your phone.
I hope that helps.
Nov 24, 2009 | Dual Car Audio & Video
I just bought a Dual XDM6820 and installed it myself into my 2000 Toyota Rav4. The unit worked great for two days. Then I went on a road trip and the unit blew a fuse. I replaced the stereo fuse and the...
If the cd's come in and out fine then it has something to do with key wire (red) . I try and always use and a adaptor harness when installing aftermarket decks. Make sure your wires are well inulated and not pinched when deck is "in its place".
Jul 21, 2009 | Dual XD7600 CD Player
The detachable face plate opens up when i turn off the ignition
This is a option you can disable in the menu, it is meant to make it easier to detach the faceplate when you leave the car
Apr 12, 2009 | Pioneer Car Audio & Video
Color code for a dual xdma7715
You need to buy a ford wiring harness. They are about $22 at Best Buy. If you want to hardwire the unit to your car then you need to get the wiring colors from Ford. It is 100x times easier to just buy the wire harness.
Mar 24, 2009 | Dual Car Audio & Video
Lost detachable face panel
To reduce theft, most car stereos with detachable faceplates are keyed together -- that is, they are not interchangeable. It is unlikely that you will be able to find a replacement faceplate, unfortunately.
Feb 25, 2007 | Akai CSV2001 CD Player
Car Audio & Video Logo
163 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
