Question about Casio FX-115ES Scientific Calculator
When adding decimals, the answer is given as an
When adding or subtracting decimals, the answer is given as an improper fraction. How do I fix this? I have tried but have been unsuccessful.
  • Casio Master
  • 7,993 Answers
There is nothing to fix (It ain't broken). However if you do not like the display format, just press the [S<=>D] key and the result will magically be converted to decimals.
If you do not want any fractions nor radicals, JUST set the I/O mode to LineIO:
Press [SHIFT][MODE][2:LineIO]
Posted on May 13, 2010
Subtracting mixed numbers
Check that picture
Dec 01, 2017 | Miscellaneous
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
My sharp el-531x calculator is sowing my answers in decimals. how do i solve this problem
If you have a key marked [change] press it to toggle from improper fraction to decimal to mixed number.
If you do not have the [change] key, press the [a b/c] key to change from decimal to mixed number. Press [2ndF] [a b/c] to convert to improper fraction.
Dec 08, 2013 | Sharp el-531x scientific calculator
I cant figure out how to be able to take a fraction and subtract it to another fraction on my TI-84 PLUS calculator
Given two fractions a over b and c over d, you can subtract the first from the second by entering
( c / d ) - ( a / b ) ENTER
The calculator will give you a decimal result, which you can (probably) convert back to a fraction by using the >Frac command. Press MATH 1 ENTER
Feb 02, 2011 | Texas Instruments TI-84 Plus Calculator
Can this convert decimal measurements to fractions of an inch
Enters a proper or improper fraction,
b?c (b { 6 digits, c { 3 digits). When
possible, improper fractions are
displayed as mixed numbers.
3 F 4 3?4
8 3 J 21?4
Single-variable functions display
decimal results.
1 F 2 0 0.25
a F b F c Enters the mixed fraction a b?c.
(a, b, c { 3 digits each, with the total
digits { 8).
6 F 4 F 6 64?6
J 62?3
"s Toggles display between a mixed
number and an improper fraction.
30 F 4 30?4
"s 71?2
"s 15?2
"s 71?2
"y Toggles display between fraction and
decimal.
55 F 24 55?24
"y 2.291666667
"y 27?24
If a result would overflow or if fixed decimal is 0, no
fraction to decimal conversion occurs. It is not an error.
Denominator must be a whole number {999.
Nov 28, 2010 | Texas Instruments TI-30XA Calculator
With the TI-84 Silver calc: what I really meant was - I want to input a set of mixed numbers (or just a regular set of one or more fractions e.g. 3/4 x 5/87) and either add, subtract, divide (or any...
Upgrade the OS of the calculator to the 2.53 MP (Math Print) version. As you can see on the following screen capture of the MODE setting, you can choose to use the CLASSIC option (the old way) or the MathPrint version.
You should notice that the Answers AUTO DEC or FRAC options allow you to configure the calculator to work in DECimal, FRACtions or AUTO (the calculator chooses whats is appropriate).
The n/d is for improper fractions and Un/d for mixed fractions.
Enjoy your new found freedom.
Here is the link to the new OS 2.53MP
Mar 25, 2010 | Texas Instruments TI-84 Plus Silver...
Answers in decimals
The calculator has two Input/Output modes, MthIO and LineIO. In MthIO the results are displayed as fractions or as radicals or a mixture of fractions and radicals. What it means, is that in MthIO the calculator does exact calculations. Radicals in denominators are gotten rid of by rationalization, fractions are reduced to the same denominators before addition or subtraction. Fractions are reduced to simplest form.
In LineIO all results are displayed as decimal numbers.
If a result is exact (fractions and radicals) it can be changed to decimal form by pressing the S To D key, the one above the DEL key.
MthIO is the default IO mode. To set it, press SHIFT MODE and select 1:MthIO. To set LineIO as the IO mode, press SHIFT MODE and select 2:LineIO
Jan 20, 2010 | Casio FX-115ES Scientific Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
Casio FX-115ES Scientific Calculator Logo
127 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
