Question about Microsoft Xbox 360 Console
I have had my xbox 360 for a little over a year. It was one of the first to come out and has not had any problems in the past year. However a few days ago it would not read any CDs I attempted to play. It would give me the READING message on the status bar in the dash for a second, and then revert back to the open tray option, as if it wasn't detecting even the presence of a CD in the drive.I tried cleaning the "eye" and that still didn't work..any ideas?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 74 Answers
It may just be broken. Mine (also an original) started doing that a year after I got it and I had to replace it.
Posted on May 15, 2010
I have one red light flashing on my xbox 360. how can i fix it?
If you have a hard drive, clearing the cache might resolve the one red light error. Also, you can try to remove the hard drive and power on the Xbox 360 Console without the hard drive to see if the red light will still occur. If it doesn't appear it is the hard drive causing the error and needs replacement, if it does flash the red light still, it is a hardware failure in your Xbox already.
May 06, 2010 | Microsoft Xbox 360 Console
Xbox 360 will not read cds of any sort, no error message
It appears your laser lens has bit the dust. It's not too expensive to replace it. you can purchase one here.
The instructions can be found here
Feb 26, 2008 | Microsoft Xbox 360 Console
Why does my xbox 360 kepps freezing when i play games?
360's tend to lock up before the "red rings of death". You get this when the system overheats and has problems with the solder coming loose. Mine took a little over a weak before it got the red rings after it kept freezing after a few min.'s of playing.
It could be overheating because the fan is not getting enough air out. try cleaning the console itself outside and using can of compressed air to get any buildup in the vent holes and fan cleared. There are a few FAQS on this site to learn about a few tricks.
feel free to comment if you have any questions. Hope this helped and remember you have a three year waranty on your xbox for the red ring and E74 error!
Apr 11, 2010 | Microsoft Xbox 360 Console
Opens in middle of game play and makes weird scretching noise
well im havin about the same problem and it sounds like you need a new dvd drive for your 360 itll cost you about $25
Jun 02, 2009 | Microsoft Xbox 360 Console
Re: Blinking green light/won't detect disk drive
If you still have a warrenty sticker call up Microsoft and tell them that your Xbox 360 has overheated, and tell them your serial code. They will tell you if your warrenty is expired, if it's not they will ask you where you live then pick up your Xbox 360 and fix it for free. If your warrenty has expired try this. Power off the Xbox 360 and when it is off press the eject button, it might open they tray. Or try opening your Xbox 360 and remove the disk drives cables from the disk drive and the motherboard and put it back together, you should never try the towel trick really, although it works it can also give your Xbox 360 3 red lights then you have to buy X-clamps and theormo paste, just do the X-clamps and theormo paste when you get one red light. I have had two Xbox 360's, when I did the towel trick it burnt the GPU, the other one a little componante came loose, sorry for my spelling. Hope this helps =D
May 25, 2009 | Microsoft Xbox 360 Pro System Console
Power supply to xbox 360
2 red lights on part 1 and 3 indicate the the console is overheating, the most common problem is the thermal paste.
You need thermal paste or it will overheat instantly, using cheap thermal paste or not using enough thermal paste will also cause problems. Use good quality paste and apply enough to make contact. You don't want to use too much, but if you use too little it won't make good contact with the heatsinks.
If you've done this before then it shouldn't take too long, but if you haven't then just take your time. You don't want to put too much on at first so do it bit by bit.
If you're still getting this error after correcting with thermal paste then the only suggestion would be to contact Microsoft but then they might not take the 360 after you have already void any warranty by opening up the console.
Apr 20, 2009 | Microsoft Xbox 360 Console
X Box 360
This exact thing is happening to not only me but to also a friend of mine. You will probably notice that the fan kicks on really high and then goes to 2 flashing red lights, this is because the 360 is overheating or thinks its overheating. My friend's 360 starts up with the fan kicked on high and then only plays for a minute or 2, followed by the 2 red lights. If its under warranty send it back to Microsoft, I took mine and my friends 360 apart and replaced the thermal paste with arctic silver, but it kind of only helped a little for mine and not at all for my friends. SEND IT BACK!!!!!!
Aug 30, 2008 | Microsoft Xbox 360 Console
Xbox 360 cannot read xbox 360 games.
the sounds like a problem with the laser in the 360. send it to Xbox and they should repair it
Jul 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Xbox360 game cases
i have mine in plasty pockets, try that.
Sep 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
