The Sanyo DVR-S300 has gone into ROOT mode and I can't use remote or set controls. What can I do.
  • Graham Weatherley Mar 29, 2008
    Sorry taking batteries out the remote did not work.
    Also could not find a battery inside the set.
    Disk runs and counts down but when switched off returns to ROOT. (No picture just a lot of mix up on screen.
    Was working on with Menu when set wnt into ROOT.
    Disk turns and counts down but no picture.
    No battery in set.!
    When turn disk off goes into ROOT
    Or when any other function like menue. Goes into ROOT
    Using Menu when set went into ROOT
  • 871 Answers
Do a hard reset so that you should achieve the necessary mode you want to access.
btw, how did you happen to go to ROOT mode?
Posted on Mar 29, 2008
  • earl norman llanera
    earl norman llanera Mar 29, 2008
    unplug player for at least 2 hours. take out the battery from the remote too.
    once you already did this,, i sure hope things would turn out fine already.
    post back if things arent well...
    fine. if theres no battery there. just leave it be. now about the ROOT, try to investigate whether you can see any reset there on the remote.
  • 13,434 Answers
Hey,
First disconnect the power from the dvd player,
if there is a memory battery, remove it for a moment.
Put the memory battery back after 1-5 minutes
plug it back in and see if the problem has solved.
If you need more asistance, let me know. Good luck.
  • 19,396 Answers
Remove battery out and put it back in, this will reset your Sanyo.
  • Ginko
    Ginko Mar 29, 2008
    It is the remote, take also battery out from remote. For reference to other experts, here is the user manual.
  • Ginko
    Ginko Mar 29, 2008
    Do the following , it is the reset procedure for sanyo cd/dvd. You will need to use the original remote to perform the procedure:
    Turn the unit on
    All the following is on the original remote:
    press SHIFT & CLOCK
    time blinks
    press SHIFT & ADJUST
    hours blink
    pressthe double arrows also called -PRESET+ to set hours
    minutes blink
    pressthe double arrows also called -PRESET+ to set minutes
    clock resumes normal operation
    Let us know how it goes.
    Regards
    President:
  • 1,950 Answers
Did you try disconnecting it from the power for a few hours to reset it?
SOURCE:
Tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
DISH Solo DVR VIP612 Limited Mode What is DISH Solo DVR VIP 612 Limited Mode?...
You can program your remote control in Limited Mode to keep from accidentally changing the channel on your TV or VCR and causing a snowy or blue screen.
  • When the remote control is in Limited Mode for TV mode, you will only be able to use POWER, MUTE, and VOLUME functions for your TV.
  • When the remote control is in Limited Mode for VCR mode, you will only be able to use POWER and the VCR functions for your VCR.
Note: Limited Mode is not used with amplifiers (AUX mode).
I hope that helps.
What is the code for a Sanyo DP26640 26" LCD TV
Hello
Remote code for Sanyo TV with Comcast Custom DVR-3 device universal remote control is
0154
1. Turn on a device (e.g., VCR or DVD
Player) and, if applicable, insert
media, (e.g., video cassette or disc).
NOTE: Please read steps 2 to 6 completely
before proceeding. Highlight or write
down the codes and device you wish to
program before moving on to step 2.
2. On the remote control, press a
device key once (i.e., AUX or TV).
NOTE: Use the AUX key to program
control of an Audio Amplifier or
Receiver, a DVD Player, a Home-
Theater-In-A-Box Device, a PVR (or
DVR), or a VCR.
3. Press and hold Setup until the
selected mode key blinks twice,
then release Setup.
4. Locate the code for your device in
Manufacturer's Codes on the back
of this user guide. Brands are listed
in alphabetical order with the
most popular codes listed first.
5. Enter the first four-digit code for
your device. If you perform this
procedure correctly, the selected
mode key will blink twice.
NOTE: If you enter an invalid code, the
selected mode key will display one long
blink and exit the programming mode.
Repeat steps 2 to 5 with a valid code.
6. Aim the remote control at your
device and press Power once. The
device should turn off. If it does
not respond, repeat steps 2 to 6,
trying each code listed for your
brand until you find one that
works. If it still does not work, try
Searching For Your Code.
NOTE: If the device does not have a
Power key, press the (Play) key
Apr 29, 2011 | Sanyo Televison & Video
Can not get my sony dvd to get off of dvd1 and it is now locked u
Go to your DVR and manually turn the DVR off. Press the STOP button for
two or three seconds. The DVR COMMAND MODE setting will display in the
DVR window. (DVD1, DVD2 or DVD3)
Set the remote to the COMMAND MODE setting that was diaplayed by depressing
both the remote ENTER key and the desired number key (1, 2 or 3) and holding
them both at the same time for 3 seconds.
You can now use the remote to set the DVR to the desired COMMAND MODE.
To do this depress SYSTEM MENU on the remote and go to SETTINGS and then
COMMAND MODE. Select either DVD1, DVD2 or DVD3. Once you delect a setting
that is different from what was set, your remote will stop working again.
Reset your remote to the desired COMMAND MODE by depressing the remote ENTER
key and the desired number key (1, 2 or 3) and holding them both at the same
time for 3 seconds. The remote should now control the DVR.
Nov 14, 2008 | Televison & Video
Tip
DISH VIP612 Amplifier Control
DISH Solo DVR VIP612 Amplifier / Receiver Control
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
  1. Press and hold the AUX button until all the mode buttons are lit, and then let it go.
  2. Press the POUND (#) button.
  3. Press the PLUS side of the VOLUME button.
  4. Press 0.
  5. Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
  6. Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
I hope that helps.
Tip
  4. Press 0.
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Sanyo DVR-DX600 Region Code
Could you pls try:
1. Remove DVD or video from the player.
2. Press the ‘Set-up’ button on the remote control.
3. Select the ‘System Info’ mode from the on-screen menu.
4. Using the remote control 10-key type in ‘1101′
5. ‘Region code’ should appear as an option on the ‘System Info’ menu. Initially the region code will be set to 2. Press ‘0′ on your remote control using the 10-keys to set to multi-region.
6. Press ‘OK/Enter’ on the remote control.
7. Finish by pressing the ‘Set-up’ button once more.
This was actually intended for a Sanyo DVR-V100E &HVRDX610 but I was made to understand should also work for DVR-DX600. This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Televison & Video
Tip
I hope that helps.
Tip
I hope that helps.
159 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
