Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Battery not charging
I have a 12hp 38'' Craftsman mower with a B&S engine. The battery is is always discharging. Where does the wire from the armature connect to?
    Guru:
  • 63 Answers
My 24HP 42" did the same. If your model is like mine, there are two black wires with a yellow connector coming down the side of the engine. Unplug those wires, and with engine running, and a multimeter leads attached to them measure for 15 volts AC. If good reconnect yellow wires, and test the single red wire with multimeter red test lead connected and black test lead to any engine ground point. Measure for 15 volts DC. My problem was that square regulator that did not convert 15 VAC to 15 VDC. If your tractor is less than two years old, the warranty will cover labor and repair. Also if your tractor's wiring has different color wires, the test procedure may be different.
Posted on May 19, 2010
I have a cc 500 bat push mower the battery charger was leftout on rain the light dont come on for charger is it fried also does it have a plug that i can plug extenstion cord in or do I n
The charger lead should have been connected to a Residual Current Device, or Earth Leakage Breaker that should have flipped the power off. There should be a reset button on the plug.
Charge the mower for 14 hours before initial use. Charge mower indoors in a dry area out of the weather. DO NOT charge in rain or wet locations. IMPORTANT: Use only the battery charger provided with this mower. Plug the battery charger into the battery first, and then into any standard 110/120 volt household electrical outlet. See Fig. 3-9 for B battery charging location. A C NOTE: If an extension cord is required, use one that is at least wire size 16 AWG. Connect the extension cord to charger before plugging extension cord into electrical outlet. NOTE: You may charge the battery with the battery removed from the mower. IMPORTANT: Always recharge battery fully. It takes 14 hours to recharge a completely discharged battery. A flashing light on the battery charger indicates the battery is less than 80 percent charged; a solid green light indicates the battery is 80 to 100 percent charged. A full charge will be achieved in less than 14 hours if the batteries were only partially discharged. NOTE: It is recommended that the mower be charged once every two months during storage. IMPORTANT: Always disconnect battery charger (or extension cord, if used) from the electrical outlet first, then disconnect battery charger from battery. NOTE: It is recommended that the mower be charged immediately after it has been discharged. Storing batteries in a discharged state could reduce future performance. WARNING: The battery contains corrosive fluid and toxic material - HANDLE WITH CARE. Keep away from children. Do not puncture, disassemble, mutilate, or incinerate. Explosive gases could be vented during charging or discharging. Use in a well ventilated area, away from sources of ignition.
Cub Cadet CC500 BAT Operator Manual Charging The Battery
Cub Cadet CC 500 BAT Review Pros Cons and Verdict
It is a 48 volt battery, so the charger for this is special. contact Cub Cadet direct for a replacement.
Service Parts
Aug 09, 2017 | Cub Cadet Garden
Older 12hp briggs and stratton engine with missing wires
should only need three... one for the kill wire ( most likely goes to the plate that the throttle cable hooks to) ... one for the charging system ( 3 amp dc charge ) or two from the charging system ( 1- 3 amp dc charge and 1- ac charge wire... and depending on how old you might or might not have a wire that goes to the bottom of the carb ( i would guess not in this case but always check )
only other wire would be for the starter if equipped...
Oct 06, 2013 | Parks Optical 13.5hp Briggs And Stratton...
My Lawn Tractor just clicks once instead of starting battery is good but it just clicks once craftsman 38" 12hp ohv
Check for power at the starter from the solenoid when the key is in the start position.. if you have power there it is the starter .. if not you probably have a safety switch malfunction . You can bypass them for testing purposes.
Jul 17, 2010 | Cars & Trucks
How can I test a riding mower regulator? (puts out 23 amps @ 3800 rpms. My dmm only goes up to 10 amps.(system won't charge battery while in operation. Can it be tested off the mower? Mower is a Craftsman...
Simplest test is to leave it on the engine, battery hooked up normally. Run the engine at normal full speed (not just idling) and use your voltmeter to measure the voltage across the battery with your DMM. If you measure 13.5 to 14 volts, your rectifier/regulator is probably OK.
It can't easily be tested off the mower. You'd need a source of AC at 24 volts to simulate the motor's stator winding, and a load that draws about 23 amps at 12 volts.
Don't forget a bad battery can cause failure to charge - it's not always the regulator.
Jul 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Transaxel broke & I replaced with new. Now engine won't start, just clicks. Battery is charged. Ran fine until axel broke
check the wiring under rider possible hit and disconnected or damaged wiring also check connections at battery -also check fuse by solenoid and solenoid
Jun 09, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
No result when i turn the key. Battery is charged. Last used a week ago with no problems.
Make sure the brake is set, and the two 'power' handles are centered, i.e., in neutral position. Both of these have an interlock switch that prevents the mower from being started. Good luck! Please rate if helpful, thanks.
May 20, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Battery discharing light is on
Does your tractor have electric clutch ? With the switch turned off try removing positive battery cable you then try touching cable to post if you get a spark you have a short in system you could also charge battery and remove positive cable from battery over night to see if battery stays up to check battery,you also have a alternater under flywheel to charge battery you should be getting an output of about 14 volts most likely not the problem
May 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower will not start will make clicking noise. did start at for one minute
Your battery is dead. Replace it.
In the winter keep a smart trickle charger on the battery to prevent it from discharging. Lead/acid batteries lose 1% of their charge per day and are basically junk in 3 months. They have to be kept charged.
May 04, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
231 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
