My Hunter thermostat that controls both my air conditioner and heating system worked fine for a couple of years. Then the date and time started getting out of whack. I replaced the batteries..problem still exists. What should I do?
If the Hunter thermostat is 3 year old or more you will need to replace the thermostat. I have serviced HVAC systems for 20 years and see this problem all the time with hunter thermostats.
Posted on Mar 29, 2008
SOURCE:
How do I set my hunter thermostat so when the heat pump comes on, how to set so the thermostat and heat strips from the heat pump sinc with each other. The model number is 44860
call a service tech, this sounds complicated. To avoid using too much energy or burning down your life savings in heating bills, a certain sequence should be followed when the thermostat operates. The actual sequence will differ depending on what equipment you have available to control, as well as your location and heating and cooling loads. The money you could save by having it done right the first time will quickly pay for a service call, then keep on saving you money after that.
Feb 21, 2015 | Hunter 44860 H Univ. Touchscreen...
Why won't thermostat turn on after I changed the batteries?
I think you may have the model # incorrect, However if you have a thermostat as in the type that are hand held, polarity of the batteries is the 1st thing I would check, then test them for proper voltage, corrosion will often interrupt that small of a voltage, clean the terminals and test it .
A wall mounted like a central HVAC system typically will not require batteries to operate, this is for memory and they will work fine even if no batteries are installed, however there are battery powered stats too, meaning non parasitic type that not powered by the transformer in the air handler.
I will include a basic drawing of a residential HVAC thermostat to show you how the 24 volts powers most thermostats.
ome > Air Filtration > Air Cleaners and Purifiers > Hunter Air Purifiers > Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer
Item #: hun30124 892f1d0d-b50f-49aa-8079-70d2dc34eb2b.png
Jun 07, 2014 | Hunter 30124 Air Conditioner
My ac system has a model#44408 hunter thermistat and a trane heat pump. The system runs but does not change the temperature to cool the home to a comfortable temperature. is the problem in the thermistat...
You have refrigerant leak or the compressor has died...not a thermostat problem...
You will need to get a tech. to take a look at it.
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Heating & Cooling
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
Furnance not heating
Make sure that the thermostat is set for the proper medium that you are using being gas or electric. Inside the cover of the thermostat should be a setting for either eletrical heat or gas heat. Set this switch for what your system is G for gas or E for eletric. This may solve your problem. Good Luck hope this helped you some
Dave
Oct 26, 2009 | Intertherm P3RA-036K Air Conditioner
I have a hunter programmable thermostat model #44155c and Im trying to wire it to my goodman furnace. Its a 7 wire system with a white,yellow,red,green,brown,blue, and orange wire. The ac works fine but...
Make sure you do not have a jumper between the red and the white. Also make sure the wire is not hanging out from behind the screws. If the heat stayes on no matter what you do. The red wire has to be touching the white somewhere.
The red is your 24v supply to the thermostat
The white is what sends the 24v to the heat side of unit.
Just a thought. If the thermostat has a O/B pin or switch on the back. Make sure it's on O. It should only be ob B if it's a Trane, American Standard or Payne.
Oct 16, 2009 | LG LSC183VMA Split System Air Conditioner
Crazy Heat
I think that I would change out the thermostat only due to the symptoms you are describing. Think the control board may be fine however, the thermostat sounds as if the internal componants are going out. Good luck on your repairs
Dave
Sep 22, 2009 | Dometic Rooftop RV Air Conditioner
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Thermostat control
I would like some help programing the thermostat in my house. Hunter, Model 44300A
Thanks,
May 05, 2008 | Hunter 30124 Air Conditioner
Open Questions:
aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...
Oct 17, 2019 | Computers & Internet
avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7
Oct 17, 2019 | AVG Computers & Internet
Computers & Internet Logo
102 people viewed this question
Ekse
Alun Cox
