Question about LG RUMOR Cellular Phone
No one can hear me when I call them or they call me
I can hear them just fine they just can not hear me. I have tried to take out the battery and nothing I do helps
I have a 2004 Acura TSX and for some reason I cant hear my radio or my navigation. It was working fine and then one day I went through some gravel and it never worked again. the radio display turns on but...
Have you tried to pull the battery for 15 mins and reset the whole car? You'll need the security code for the deck after connecting the battery. It's usually in the owner's manual...
Jan 27, 2015 | 2004 Acura TSX
2001 ford taurus wont start only clicks new battery
I would check the wires on the starter, it might have a bad connection, also your starter might be bad.
Jun 16, 2012 | 2001 Ford Taurus
My 2005 caravan won't start. When I turn the key I hear a clicking sound but it doesn't start. It worked fine earliar today.The battery is fine for now.
Possible causes are: 1. Loose or corroded battery cables. 2. Bad starter 3. Dead battery. Try tapping on the starter with a hammer while someone is holding the key in the start position. If it starts then replace the starter. Thanks
Sep 05, 2011 | 2005 Dodge Caravan
I replaced the batteries in my Siemens Pure 700 BTE but the hearing aids do not work. I tried several sets of batteries of different manufacture but they still do now work. The worked just fine until the...
If indeed you are, you need to take them back to the Audi, he will need to assess whether the receivers have failed or if for some reason the instruments have failed.
Aug 01, 2011 | RTO 2 Siemens Pure 700 Open Fit Hearing...
R REG PUNTO 16V SPORT engine not running battery fine electric windows lights etc work so battery fine turn key and nothing ...
If you hear a clicking you still might not have enough battery power to start it.
If you hear the motor turn over, but not start you might have a fuel, or spark issue.
Feb 28, 2011 | Fiat 500 Cars & Trucks
1997 Mercury Villager minivan, turns over, doesn't crank. I can hear the fuel pump hum on before turning key, but won't crank. starter fine, battery/cables fine, fuel fine. For a while it would do this,...
try starting in neutral and see if it helps. Could be a bad starter solenoid or corroded battery cables at battery. Clean the connections at the battery including the 2 small ones on the positive post.
go here for help
http://groups.yahoo.com/group/villagerquest/
Jan 11, 2011 | 1997 Mercury Villager
I could hear him, he could not hear me unless I use my bluetooth
Try calling someone else, if that is the same then your handsets Microphone is damaged, if this is the case then change the Mic and all should be fine. If the phone is still under warranty its best to get it done for free under the warranty.
Jun 14, 2009 | LG Dare VX9700 Cell Phone
93 LX 5.0 replaced battery, ran fine then would not start
sounds like you have a good battery, get the car started put a voltmeter to wire connected to the back of your alternator. if you have at least 13.25 volts you have a good unit if any lower replace the alternator
the click sound you are hearing comes from your relay it is getting low voltage from the battery. because the battery has no juice caused by a bad alternator
hope to help shack
Apr 15, 2009 | 1993 Ford Mustang
Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Sep 01, 2007 | GN Netcom (9120-48) Wireless Headset
LG RUMOR Cellular Phone Logo
65 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
