Question about Maytag Performa PAV3200
The dryer is not rotating but it is getting power because when i turn the knob to a setting, i can hear it ticking.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
There are several reasons you could be having this issue. Most likely it's due to a broken belt from the motor to the tumbler cam (not expensive to repair) or it could also be that the motor has fried (very expensive if not under warranty) and lastly, a bad breaker (could be at fault. You can go to www.RepairClinic.com. They provide you with free diagnostics, and fairly priced parts, plus friendly helpful instructions for DIY repair. . . and yes, the DIY instructions are also free.
Hope this helps FixYa! Please rate up this solution if you found it helpful or share the love by sending a quick testimonial.
Posted on May 13, 2010
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Admiral dryer won't turn on or start
It could be a broken door switch. With the door open, look for the plastic tab that comes through the dryer frame. this is the switch. If it is broken, you know what the problem is. If not, depress the tab and carefully try to start the dryer. If it starts, then it is not your problem. I have changed two before. very simple.
Apr 24, 2014 | Dryers
My dryer's cotton/time dry/wrinkle free option know turns freely. Dryer will not start.
Take the other knob from the other switch nd put it in that place. It should turn then . You will be able to turn it on by a pair of pliers until you get a replacement knk.
Feb 22, 2013 | Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
The dryer model # PYE3300AYW The dryer has power but will not turn on when the timer/start knob is pushed. You can hear the timer ticking, but nothing else happens. What are the possible causes for this?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Maytag Dryers
The problem I have is I set the timer and you can hear it ticking over but the drum isn't moving
Did you pul the timer knob OUT? This is how alot of dryers are started..
Feb 21, 2011 | Dryers
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Washing Machines Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
