Question about Vizio L37 Television
When we turn tv on its fine untill few minutes tv starts flickering looks like a disco light
    Brigadier General:
  • 4,090 Answers
Sounds like a dry joint or a loose wire.
Firstly though check that the coax is on firmly as it may be the problem. To check its not at the antenna end of the coax remove it and place a wire coat hanger or even your finger on the tV antenna inlet and see if it still flickers. If not then start investigating the antenna and coax.
However my bet is a dry joint on one of the SUS boards as this is fairly common on Vizio and LG Tv;s as there was a whole bad batch out of Korea.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
Constant clicking on all audio channels
If all connections are good, I would suggest its picking up "spurious" signals from something electrical. There could be something (Even a fluorescent light flickering , which the receiver is picking up. Check around for something flickering or turning on and off. Electrical "spurious" signals can be sometimes difficult to detect but it seems that may be your problem. You may have to go round the house switching off 1 electrical appliance at a time ( And lights) to see which one is doing it. LED transformers for low voltage lighting can do it as well. Hope this helps, Cheers
Mar 15, 2014 | Audio Players & Recorders
My Mitsubishi WD-65638 turns on then flickers and turns off?
Flickering must be due to the fault to lamp itself. If you wish to get more details, check this link.
Mar 03, 2013 | Mitsubishi WD-65638 65" DLP HDTV
LG 37LB1DA flat panel TV
most likely the inverter board is faulty, I think this model has two of them, look on ebay for cheap replacement.
Mar 24, 2017 | LG 37LB1DA Television
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
32" 32lc7d after a few minutes, flickers, then goes dark.
There are no fans in this model but it looks like either the backlights in the screen are breaking down after they have warmed up or a problem in the inverter board, again part of the driver circuit breaking down after a period of time. They inverter boards can sometimes be replaced seperatly but usually come with a new screen which if the backlights are at fault then the screen would need to be replaced.
Feb 04, 2010 | LG 32LC7D Television
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
Flickering/jumping picture
I HAVE THE SAME PROBLEM. TV WAS FINE UNTIL A FEW MONTHS AGO. OF COURSE ITS OUT OF WARRANTY. FROM WHAT I HAVE READ, AND BEEN TOLD, IT IS THE POWER SUPPLY TO THE UNIT. IT IS DEFECTIVE, OR IT OVERHEATS AND TRIES TO SHUT DOWN. A LAW SUIT IS IN PROGRESS AGAINST WESTINGHOUSE TO RESOLVE THIS MATTER. KINDA REMINDS ME OF THE XBOX 360'S WHEN THEY CAME OUT. ALL YOU CAN DO IS TAKE IT IN FOR SERVICE. OR, YOU CAN KEEP TURNING IT ON AND OFF, LIKE I DO. I HAVE HAD THIS TV ON ALL NIGHT BEFORE WITH NO PROBLEMS. AS SOON AS I START CHANGING STATIONS, OUT IT GOES. GOOD LUCK. WESTINGHOUSE WILL NOT EVEN EMAIL ME. I HAVE TRIED SEVERAL TIMES TO CONTACT THEM. I HAVE HEARD FROM THE LAW FIRM IN CALIFORNIA THAT IS GOING AFTER THEM. GO ONLINE, AND JOIN THE CRUSADE.
Mar 25, 2009 | Westinghouse SK-32H240S Television
Headlights flickering
This could be caused by a lot of different things,,but usually it is the fault of the Headlight Relay.
Try replacing the relay before going further.
Jan 30, 2009 | 1983 Ford Thunderbird
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Vizio L37 Television Logo
224 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
