Question about HP Photosmart C6280 Printer
Display window says "out of paper" and it's not. Rollers appear to be ok. Any suggestions?
    Novelist:
  • 142 Answers
Please perform the steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=uk&lc=en&dlc=en&product=3194498
:) Dr Tony
Posted on May 13, 2010
Shredder not accepting paper. The rollers appear to be working properly and there does not appear to be any paper jams or blockages. No unusual noise from mechanism and rollers do not appear to be loose....
try inspecting the rollers, make sure its plugged in, try emptiying the canisters, if that doesnt work,take it to radio shack or staples,they can help you probbably for free
Nov 06, 2013 | Fellowes DM15C Shredder
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper jams no matter what stock I use; Lexmark e232
Slipping paper feed rollers is probably causing the jamming. Remove the paper tray and tip the machine back so that you can access the feed rollers from underneath. A good technique to isolate this problem is to remove the rubber feed tires, turn them inside-out and refit them. If it now works OK you need to get new feed rollers.
Jun 01, 2009 | Lexmark E232 Laser Printer
I have just purchased ink cartridge 830 black for canon ip 1800 but the lights are blinking orange please tell me why this is happening
I received this response from canon.com. Hope it helps you.
feed paper due to the feed roller's slippage. If paper does not feed
1. Open the Printer properties.
For Windows Vista
a. Click / Select 'Start' from the bottom left of the Windows screen,
'Control Panel', 'Hardware and Sound', and then click on 'Printers'.
Note: If you are in 'Classic' view, Click 'Printers' directly from the
'Control Panel'.
b. Click your right mouse button on the listing for your printer, and
then select 'Preferences' from the menu that appears.
Faxes.'
a. Click 'Start' from the bottom left of the Windows screen, and
For Windows 2000
then select 'Properties' from the menu that appears.
8. Click 'OK'.
If the issue continues to persist, try fanning the paper before
reseating in the automatic sheet feeder.
Follow these steps to fan the paper in the Auto Sheet Feeder(ASF):
1. Remove all documents from the ASF.
2. Check for any obstructions.
3. Fan out the sheets of paper so that they do not stick together.
4. Align the edges of the paper.
5. Insert the document stack, face up, into the ASF until you hear a
beep.
6. Adjust the document guides to the width of the document.
If fanning the paper does not help resolve the issue then the iP1800
printer will require service.
special toll-free number for email customers with
unresolved issues and speak to a technician* by dialing 1-866-261-9362,
Monday - Friday 10:00 a.m. - 10:00 p.m.
Dec 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
My HP OJ 7310 all-in-one did not pick up papers.
the first ting I would do is clean the paper feed rollers with a cotton pad and alcohol. The rollers may have a build up of paper dust that are makind the rollers slip.
Sep 27, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Can't Print
HP Paper Feed Cleaning Kit - Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00754199&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
ou may not have the paper width set snug to the paper to feed correctly.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553862&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
Consult http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00601439&cc=us&lc=en&dlc=en&product=439488 regarding "out of paper" errors Paper cleaning kit is included in this article.
Apr 19, 2008 | HP Photosmart 3210 Printer
Printerjam
A paper jam error message will appear if the printhead is not correctly installed. Try removing and reinstalling the printhead again, but make sure it snaps into place. Try loading a sheet of plain paper and press at the same time copy+cancel; hold them down until the printer feeds the paper. The paper will go through the rollers and come out blank.
Apr 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Photosmart C6280 Printer Logo
69 people viewed this question
Seeker5211
Seeker5211
