Question about Singer 3116 Simple
I was sewing last night an all of a sudden it just stop working i let it cool for 20 min and nothing what do i do could it be the moter it is a singer simple 3116
    Genius:
  • 1,788 Answers
There is probably lint or thread caught in the bobbin area and causing it to overheat. Call Singer at 1-800-4singer and they can advise you,
Posted on Aug 27, 2010
My Janome 2030 DC suddenly stopped sewing correctly and started making fast beeping sounds and the needle goes up and down. I have tried unplugging and plugging, rethreading... nothing works.
http://janome.com/siteassets/support/manuals/computer-models/inst-book-2030dc--jnh1860-en-.pdf
The above may well be the manual you have. The peep peep peep is listed at the end of the manual. Sadly, it simply mentions invalid operation. That said, below is a service manual that does include this mode (although at first glance it may appear otherwise)
https://www.craftsy.com/blog/2014/11/how-do-i-fix-my-sewing-machine/
This last link just might prove helpful.
How Do Fix My Sewing Machine Troubleshooting Your Janome
Jun 06, 2017 | Janome Sewing Machines
When you push foot pedal c3 comes up and beeps 3 times
Don't know what machine you have, but this may help:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwigsLfzlJbKAhVB7WMKHYHZAHwQFggdMAA&url=http%3A%2F%2Fwww.singerco.com%2Fpdf%2FFC_Plug_In_Instructions.pdf&usg=AFQjCNEqPAnJbHodHAqfFC95mKH913qZVA&cad=rja
Singer One Instruction Manual Helpful Messages
Error code & would not sew after 2 uses.
4/19/2012
Customer review by DeZooMT
1.0 stars by DeZooMT
Got this as a Christmas gift. Have used it twice since then for little things. Seemed to be fine. Decorative stitches worked and the straight stitches turned out good too. But didn't last. Just took it out to use on a bigger project and it just stopped sewing. The foot pedal wouldn't work at all. The back stitch button would sew though. If you tapped the pedal aggressively at times it would delay and then jump forward 3 stitches and then display the C3 error code saying the foot pedal was disconnected, which it clearly wasn't. Tried the Singer CS line. Was caller number 20, was on hold for 40 mins when I finally got down to caller number 4. All of a sudden the operator hung up the call and stated "their offices are now closed." I was furious. Needles to say, it went back to WalMart and I won't be buying another one.
Jan 06, 2016 | Sewing Machines
Bernina artista 165 has always worked perfectly. Ran last night. I turned it off. When I tryed to turn it on today there was no power - checked all cords and outlets. After looking it over for 30 min. I...
Congrats on your upcoming marriage
If the attachment to the machine is 2 prongs (male) and the cord has two small holes for the prongs (female) you can try gently squeezing the plug with the female end to make the contacts a bit tighter. It sounds like the connection is not making contact properly
May 18, 2017 | Sewing Machines
Apparently,where power cord comes into housing /stress relief has worked loose.If cord is user serviceable(probably not) UNPLUG UNIT while servicing.Might be as simple as interior stress relief has worked loose,but again,unplug unit while tightening this.Are you using a foot treadle?? also,power cord itself may be bad.
May 09, 2017 | Sewing Machines
Babylock bl3 437
What are you sewing? Might be way too heavy to sew on this little machine.
Motor is failing if heavy use motor is dying or voltage regulator inside machine is gone bad.
Apr 19, 2014 | Sewing Machines
Futura XL 400 all lights flashing
could have a short in the machine or if the machine is computerized there could also be a problem there.
Mar 25, 2014 | Sewing Machines
Machine just stop sewing for no apparent reason.
The circuit breaker on the motor has tripped.
You might be sewing material that is too heavy/thick and it's heating up the motor. It will take awhile to cool and work again. Get a heavier duty machine, this one won't last long using it as you are.
Feb 03, 2014 | Euro-Pro Sewing Machines
Janome j3-20 suddenly stopped working
I would suggest taking the machine in to be checked
Jun 07, 2012 | Janome Sewing Machines
My singer 6038 sewing machine suddenly stops working after sewing for a 5 min. stretch of time. i press the foot down as far as it goes, and all i hear is the motor--but the needle doesn't move....all...
I think that you need a new motor, I saw one online for $90 and it looks like it would be easy to install yourself, mostly plug in and bolt to the machine, I saw it on www.sewingpartsonline.com but there are other sites,
Apr 22, 2011 | Singer 6038 Mechanical Sewing Machine
Fabric won't feed forward
Do the feed dogs move up and down? If they dont the plastic gear underenth has probably broken you can take this to a singer dealer and have them replace the plastic gear with a nylon one which would last longer than that did
Jul 16, 2009 | Brother LS-1217 Mechanical Sewing Machine
Singer 3116 Simple Logo
35 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
