Question about Evenflo Trail Tech Framed Baby Carrier
What is the maximum baby cargo weight?
What is the maximum cargo weight?
A ship with a waterline area of 20000 square meter has vertical sides at the water line plane. In seawater with density of 1025kg/cubic meters, the draught of the ship is 3meter.I am confused,
The weight of the ship is 20,000*3*1,025 = 61,500,000 kg; To have a 3m draught in fresh water, it would have to weigh 20,000*3*1000 = 60,000,000 kg; That means it needs to remove 1,500,000 kg (1,500 T) of cargo before sailing into fresh water.
Mar 22, 2017 | Homework
What is the weight limit for hauck infinity
Hi
We would recommend you contact Hauck directly for assistance -
Home
Sep 02, 2014 | Hauck Infinity Stroller
What is the gross weight limit that a 2002 Pt can carry ?
The maximum gross vehicle weight is 3973 pounds. The 2002 PT Cruiser's curb weight (AT) is 3190 pounds; the curb weight (MT) is 3108 pounds. Thus you can't have more than about 800 pounds of cargo/passengers. The max trailer load is 1000 pounds (for the 2010 and probably for the 2002).
I hope this helps.
Jul 13, 2012 | 2002 Chrysler PT Cruiser
Hi when should I move my baby to the next car seat she is 10 months and weighs 20 lbs
Good Afternoon
The Maxi Cosi CabrioFix can be used to a maximum weight of 13kg which is around 28/29lbs. We recommend that you keep baby rear facing for as long as possible as this is the safest way for children to travel due to the development of the neck and spinal muscles.
At a minimum weight of 9kg she can be moved into a standard group 1 carseat.
Aug 08, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Need to know the maximum load weight capabilities of this bike for travel loads
Rider, passenger, accessories and cargo should not exceed 160kg/352lbs. Cargo weight should not exceed 30lbs. That's from the owners manual, see same info and more at link below.
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/CB250-1992.pdf
Cheers.
Apr 22, 2010 | 1992 Honda CB 250 Nighthawk
Towing capacity for an Isuzu I370 pickup
As listed in the owners manual.
Weight of the Trailer
How heavy can a trailer safely be?
It depends on how you plan to use your rig. For
example, speed, altitude, road grades, outside
temperature and how much your vehicle is used to
pull a trailer are all important. It can also depend
on any special equipment that you have on
your vehicle, and the amount of tongue weight the
vehicle can carry. See “Weight of the Trailer
Tongue” later in this section for more information.
Maximum trailer weight is calculated assuming
only the driver is in the tow vehicle and it has all
the required trailering equipment. The weight
of additional optional equipment, passengers and
cargo in the tow vehicle must be subtracted
from the maximum trailer weight.
The following charts show how much your trailer
can weigh, based upon your vehicle model
and options.
2WD Extended Cab Axle Ratio Maximum Trailer Weight GCWR*
Automatic Transmission,
2.9 L Engine 3.73 3,100 lbs (1 406 kg) 7,000 lbs (3 175 kg)
Manual Transmission,
2.9L Engine 3.73 2,100 lbs (952 kg) 6,000 lbs (2 721 kg)
4WD Crew Cab Axle Ratio Maximum Trailer Weight GCWR*
3.7L Engine 3.73 4,000 lbs (1 814 kg) 9,000 lbs (4 082 kg)
*The Gross Combination Weight Rating (GCWR) is the total allowable weight of the completely loaded
vehicle and trailer including any passengers, cargo, equipment and conversions. The GCWR for your
vehicle should not be exceeded.
Aug 26, 2009 | 2006 Isuzu I 370
Britax Boulevard-Is there a weight limit for latch system?
The weight limit for the UAS / Latch system is 48 Lbs. Read your owners manual for both the Car seat and your vehicle to be sure of all the regulations.
Jul 03, 2009 | Britax Boulevard
How much weight can I tow with a 2007 Toyota Avalon?
Towing capacity:
454 kg (1000 lb.)
Towing capacity means the maximum
gross trailer weight (trailer
weight plus its cargo weight) that
your vehicle is able to tow
Mar 16, 2009 | 2007 Toyota Avalon
Evenflo Trail Tech Framed Baby Carrier Logo
Top Evenflo Baby Gear Experts
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Stitch85
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
