Question about AO Smith Centurion 1081 1.5 Hp Standard Threaded Shaft Motor
Ours is loud its a 2.0 hp - AO Smith Centurion 1081 1.5 Hp Standard Threaded Shaft Motor
    Genius:
  • 1,198 Answers
As pumps age, the bearings wear out. You may be able to get the bearings replaced at a rewinding shop. They can check your windings at the same time. It's always a good idea to have a spare pump handy. That way there is no down time while one is being fixed. A pool can get out of control quickly with no circulation.
Posted on Nov 29, 2013
HP6830s Fan is too much loud
I would try blowing out the dust and/or extracting it out with the wand on your vacum cleaner if you don't have a shop vac handy. I that doesn't help you would need to replace he fan.
Our shop charges about 70 for the total repair with return shipping.
Mar 04, 2014 | HP Compaq 6830s Laptop
Our HP5060N/ HP PL4260N Plasma HDTV made a loud pop sound and then we lost the picture - still have sound. My son was playing Playstation at the time. Any idea what the cause is? Is it worth the cost of...
Hi, I have just experienced the exact same loud pop sound. Then no picture or sound. Just died. Spoke with a rep at HP and was told that this (having owned for 4 years) is out of warranty and the "main board" has died. It will cost $629.00 plus tax to repair. This would provide a 90 day warranty on those parts replaced. It's about the same to buy a new tv! So I am throwing this JUNK away and will never buy HP again. Best of luck to you all!
Feb 23, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
When an incoming fax is arriving our fax at work is beeping very loudly, how do you turn it off.
Hello, it may be possible the the fax is in diagnostic mode or the ringer volume is turned up. 1) go to the administration tab on the control panel 2) go down to the initial setup 3) go to fax setup menu 4) go to fax receive settings 5) Check the ringer volume should be set to low (default) or to off for no sound. In the troubleshooting menu - set the fax speker mode to NORMAL (default). I hope this will assist with your problem.
Jan 13, 2011 | HP® LaserJet M5035 MFP Laser...
I have a Sabre 1846 HV. The transmission began to make a loud squealing noise and won't pull the mower. How do I evaluate the problem? How do I remove the frame to get to the transmission?
Input shaft pulley splines are stripped.Input shaft is forged steel and the pulley is cast so 99% of the time only the pulley will need to be replaced.6 bolts,hydro lever,tow rod and brake rod needs to be removed.Our shop does about 1 Sabre every 2-3 months with this same condition.Takes less than 2 hours time to repair.
May 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I shut off the ringer on HP Photosmart Premier C309
Press the Setup button, go to Basic Fax Setup, scroll down to Fax Sound Volume, select Soft, Loud or Off. On ours, "Soft" is way too loud.
Dec 01, 2009 | HP Photosmart Premium C309A All-In-One...
HP P3005X
So the noise existed prior to replacing the fuser?
The first thing I would suggest is trying a different toner cartridge (since I can't hear it for myself), but it's never a bad place to start.
Mar 21, 2009 | HP Office Equipment & Supplies
When printing, the printer makes a loud sound
I first guess that it is the drum going out. If you have changed the drum......it is more than likely your fuser. Have you ran a supply check to get the status on your supplies?
Feb 18, 2009 | HP LaserJet 2840 Printer
Top loading washer whirlpool
When we move the drum, even with our hand, about 1/2 way through, there is a loud clicking, popping type noise? Sounds like a train is coming through the house before it stops the cycle?
Dec 20, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
AO Smith Centurion 1081 1.5 Hp Standard Threaded Shaft Motor Logo
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
