Question about Epson Stylus Photo 1400 Printer
Colors don't match, or even come close to the screen. There are many options in the print menu, which is best? I print from Photoshop, CS3, on premium glossy stock
    Brigadier General:
  • 4,090 Answers
You will rarely get what you see on the screen without lots of experiment. The reason being that your screen is Backlit, so what you see is not what you are going to get. Often that pic that has a nice glow appears quite ordinary and even darker when printed. Print thumbnail first and then alter parameters and print thumbnails again till you get as close to the onscreen pic as you can.
also use some of the customizable features in PRINT properties when you send it to the printer
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
Color doesn't look like what is on computer screen... printing from InDesign and Photoshop... same results from each program.
first of all, your screen is probably not correctly calibrated to show the colors right. Same goes for your copier, try calibrating the colors. Press the menu button (it's a button next to the screen, looks like a star with a head around it)
- Then press Adjustments/Cleaning
- Auto Gradation Adjustment
- Full adjust
- Print page 1
- Put the paper on the copyglass, with the black toner facing the back of the machine.
- Press Scan
- Then Print page 2
- Scan page 2
- Print page 3
- Scan page 3.
Now the colors are calibrated. If it still doesn't match, try calibrating your computers screen so you can see the real colors.
Dec 21, 2010 | Canon imageRUNNER C3220 Color Copier
I just installed a Canon mx300 on my Mac (runs 10.4.x) and all seemed to go well. I can print but the black letters don't print black (actually, the same happens if I have colored text mixed in). It's...
If the colors in your document don’t look right, you can change whether colors are managed by ColorSync or your printer.
To change color management options for printing:
Open the document you want to print.
Choose File > Print.
If the Print dialog contains only two pop-up menus and some buttons across the bottom, click the disclosure triangle beside the Printer pop-up menu.
Choose Color Matching from the print options pop-up menu.
Select one of the following options:
Select ColorSync if you want the application you’re using to control the color management of the printed output.
Select “In printer” if you want the printer you’re using to control the color management of the printed output.
If you select ColorSync and don’t believe the correct profile is selected for your printer, you may be able to change it. If you see a Profile pop-up menu, choose Other Profiles from the pop-up menu, and select a new one.
I hope this info will help to sort out your problem..Regards
Jan 08, 2010 | Canon MX300 Office All-In-One Printer
Adobe Photoshop CS3 Problem Could not complete the command because the scratch disks are full
simply change the location of the scratch disks on your hard drive by using the preferences option in the tools menu. that should do the work.
Nov 12, 2009 | Adobe Photoshop CS3 10
Phaser 8560 Colors are Off
Here are the directions for Tec Color correction. If this doesnt work then replacing the print head is the most likely solution. The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use. TekColor Description Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display. sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications. Euroscale: Matches Fogra glossy paper specification. Commercial: Approximates U.S. commercial press target. SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray From the workstation, select the color correction in a supported driver. Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS): NOTE: Some of the color corrections are grouped under Office Color or Press Match. 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed. 3. Click on the [TekColor] tab. 4. Select the required color correction. Apple Macintosh OS 9.x: 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [General], and then select [TekColor] from the pull-down menu. 3. Select the required color correction. Apple Macintosh OS X, (version 10.2 and higher): 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu. 3. Select the required color correction.
Jun 08, 2009 | Xerox Phaser 8560MFP Laser Printer
Photoshop cs3 install problem
First of all follow the instructions on this kb file:
http://support.microsoft.com/kb/315346
If you have previously installed cs3 you may have some residual files from the previous install still lurrking in the system files and registry which need removing. Or it may be that your cs3 installer files have become corrupt. to check this simply, do a file copy of the installer. If it copies ok it is likely not corrupted.
All the best
Sean
PiDigital.co.uk
Dec 16, 2008 | Adobe Photoshop CS3 10
Creating Halftone Dots
in photoshop you can use a filter to create dots you can actually see on screen, cant remember exactly where it is, but it is in the filter menu. Also to print halftone dots you hit print and go into the print preview dialogue box, click on the screens button. another dialogue opens uncheck use printer defaults. This allows you to specify what frequency angle and dot shape you would like for each color you are printing. By default CMYk are specified for the layers visual space, other spot colors can be added using channels and will show up within this dialogue along with CMYK options. however, you can only have one channel selected at a time to get it to print correctly.
Similarly in illustrator, the options are in the print dialogue. detailed info about each of these processes can be found in the help menu of the respective programs. you may want to check out this link. Many of these questions are answered in this forum all the time. http://screenprinters.net/articles.php
Sep 13, 2008 | Adobe Photoshop 7.0 for PC
Gradients and images appear jagged in Photoshop CS3
make sure u have the latest graphic card installed on ur mac, so that it matches with the compatibility of photoshop cs3
May 19, 2008 | Adobe Photoshop CS3 10
Printer: Canon PIXMA MP610 Operating system: Mac OS 10.4 Problem: Printing 4x6 photos is excruciatingly slow from iPhoto and Photoshop CS3. I thought it may have been something to do wireless printing,...
When printing from programs like that, usually the "BEST" option is selected for the print quality.. Try going into the preferences and choosing a lower quality.
If that doesn't help, for Photoshop, you can "save for web and devices", choose PNG and then save to desktop, and use another program to print the file. Or when in the print dialogue, make sure "printer manages colour management"
Not too sure about Iphoto print settings, but there may be something in there.
Apr 11, 2008 | Office Equipment & Supplies
Color printing problem~only green, yellow, blue
TekColor
Description
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
Epson Stylus Photo 1400 Printer Logo
171 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
