Question about Mitsubishi VS-60607 TV
Trying to output from my laptop via s-video. Output = VHS S-Video, TV screen rolls continuouslyyet picks up image from laptop. I am pastor of this church and no users manual exists. Help!
  • lindacpope May 13, 2010
    Is there any way I can use images from my laptop on this TV?
    thanks for your help
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This is a early 2000 model and not a true HD set. On the back you may find a input for HD and to the right of it two additional jacks marked V snyc and H snyc.
Vertical and Horizontal sync. At one point there was available a adapter box for this as the models with these two extra jacks require external help to lock the picture stable.
What I am telling you is you have a unit not compatable with the signal you are trying to connect to it.
This problem also happens with many newer LCD and some Plasma sets that will not accept signal from. With normal signals the sets work fine but sometimes older and newer units are just not compatable.
SD TECH
Posted on May 13, 2010
  • SD Tech
    SD Tech May 13, 2010
    No, I think there is no way it will work with a computer in any mode.
    Please consider that I have been honest with you and not tried to give you false hopes and sometimes it is not easy to tell someone news that is not good.
    consider also I am still here if you have further need of help.
    SD TECH
I am trying to copy VHS to DVD [using quality DVD-RW] but keep getting screen message of NO SIGNAL - Please check connections.
Hi try this set up to check if you're scart set up isn't the problem connect 3 rca lead to the output of the vcr into the input of video recorder then plug 3 more leads from output of video recorder into the TV set you're TV to AV INPUT AND set YOURE VIDEO RECORDER TO THE CORRECT INPUT MODE ...good luck
Aug 03, 2015 | Televison & Video
Video Not Supported
You would be better trying to connect from the laptop VGA to the TV Scart. But you will still need to set your laptop up to output a screen resolution that the TV can display.
Sep 19, 2013 | Televison & Video
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
How can I adjust images to dvd?
There are two ways. One is the old way and the other by computer.
First the old way, you can get a video processor/mixer. These vary in price depending on how much you want to improve the image or add things or even do tricks. The video player ouput is fed into the box and the output to TV so you can see the effect the box has on the picture. Most will improve signal, colour and stop picture rolls and jump (they won't deal with macrovision). Some have sound controls too! They were used a lot for camcorder work in the past. So you might get one cheap on E-Bay.
And the new way is to connect the video to your PC and you can get software to digitally remaster the video, which it will then output to a DVD recorder. If you have a PC that can handle the big video files, it's more economic and you will get heaps better images.
Jun 30, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Connecting and recording camera with s video output on 1221 tx
The cam setup you're trying in your surgery is similar to the type I often setup in Dental operatories for there intra-oral cameras.
You need an tuner, if your external has S-Video port, you can simply plug into it and use windows media center or the cards software(if it came seperate) to record from the s-video feed.
Then you can hook the S-Video output from the laptop to the TV monitor in question and run the laptop in mirrored mode to show the same image on both screens.
Hope this helps,
Chris
May 26, 2009 | HP Pavilion dv6000z Notebook
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
Hooking a laptop to a lcd tv
If your LCD TV has VGA input, then you can buy a cable that goes vga out of laptop to VGA in of TV... Also you can get an audio cable that goes from line out of your laptop to 2 rca jacks for your TV...
Radio Shack sells both types of cables - and you can also buy them from many online retailers if you look for video or audio video cables... I got a paired set from pcconnection.com
Nov 20, 2007 | Toshiba Satellite A105 Notebook
Mitsubishi VS-60607 TV Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
