Question about Homelite Mighty Lite Lawn Trimmer
Trimmer won't start
I have a homelite z830sb trimmer that won't start. It has spark and I just changed the fuel filter. Motor starts temporarily runs for about 1-2 seconds then quits. Any suggestions on where to look next would be appreciated.
  • Homelite Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
My homelite trimmer is very hard to start back after used for a while. What is the problem actually?
coil failing when hot or the spark plug same reason
carby fuel vaporizing in combustion cylinder
rings loosing compression due to age of trimmer
Homelite Trimmer Parts
Oct 24, 2016 | Homelite Garden
Check spark?
Benjamin, remove spark plug, attach plug wire onto plug, hold end of plug against cylinder head or a metal fastener that you know is going into engine for good ground. Make sure engine switch is in the on position, now pull engine over, observing the gap in plug for spark. If no spark get a new plug and try.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to check for Spark Plug Fire in any engine
How to Check the Spark Plug of Trimmer or Edger
Homelite String Trimmer Won Start No Spark
Jun 17, 2016 | Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Bulb will not prime
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Apr 22, 2014 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite Easyreach Model # UT20044A that will start, but then dies. Cleaned the filter, spark plug but still dies
Check that the carburettor and fuel lines are clean. If the unit has not been used for a while the gas (petrol) will evaporate leaving the oil behind to choke up the fuel system. Dirty fuel will do the same. When adding fuel use a funnel with gauze filter in it and always empty the fuel tank and then run the motor until it dies when you've finished work.
Sep 09, 2010 | Homelite Mighty Lite Lawn Trimmer
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
How to remove clutch on model z830sb
The clutch interior must be turned the same direction as the engine to loosen (reverse threads), tapping with a screwdriver and hammer usually does the trick. When you install the new clutch make sure you apply an anti seizing compound to the threads.
May 26, 2009 | Homelite Garden
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Mar 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
472 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
