Question about Tomtom ONE GPS Receiver
It gives bad directions. Is there a way to reset
It gives bad directions. Is there a way to reset it?
    Brigadier General:
  • 4,090 Answers
Usually bad directions is a result of a low battery. That is assuming it often takes a long time to give the instruction or says turn right when it should be left.
The unit should be fully charged by AC or USB orior to plugging into vehicle power.
Also check that you have NOT got shortest route selected as this is often misleading in the way it takes you to your destination. Shortest can be the most torturous or even the longest in some instances.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
Re bad disc message. the disc is stuck inside the unit. Initializes, cannot eject disc, then gives a 'bad disc' message.
Hi. I would contact Arcam directly for this - there may be a reset action you could perform or they could diagnose the fault further.
HTH
http://www.arcam.co.uk/advice/contact.htm
Jul 13, 2016 | Arcam Solo Mini Compact stereo receiver...
Purchased a mvwc400xw washer in 2012. Will not drain and spin. We completed the 3 clicks clockwise and 1 click counter clockwise to get some type of code. Does not give any code. Any suggestions?
are u saying once its reset it does spin? the drain problem can be a clogged water pump. a bad clutch or belt depending on weather its direct or belt driven, also a bad motor coupler will not allow it to spin either other wise u may have abad control board issue
Feb 28, 2015 | Maytag MVWC400XW Washer
My dlink 600 cant give blue solid color so its not functioning
Have you tried a reset? Have you checked/reseated ALL the cables? If you use a Ethernet cable directly from the ISP modem. or the D-Link, does it work? Perhaps the D-Link is bad, it's hard to say without eliminating the components one by one. Try D-Link Support for a user manual : http://www.dlink.com/uk/en/support/product/dir-600-wireless-n-150-home-router
Apr 07, 2013 | D-Link DIR-600 Router
The jet direct card is not showing up on the configuration page
Two possible problems:
1. Bad formatter, not liklely if you have used this printer with this jet direct card for a while and have not removed the card from the printer.
2. More likely either bad or in need of reset jet direct card. I am going out on a limb and guessing that you have a Jet Direct 615 card. There is a small chance that the card just needs to be reset. To do this you must perform a cold reset of the printer. Any custom tray settings that you have made will be lost during this process as will any network settings. To cold reset, turn printer off and unplug the network cable. Hold the "checkmark" key and power on the printer. Keep holding the key until all three leds turn on solid. Release the checkmark key and use the arrow keys until "COLD RESET" shows in the display. Press the checkmark key and until will perform a cold reset and restart. Plug your network cable back in and print a configuration page. If card is working again great, if not, it is likely that the card is dead and will require replacement.
If card does work, you will want to ensure that the Jet Direct card has current firmware on it. Use the HP Download Manager to update the firmware on your Jet Direct card.
Good Luck.
Apr 18, 2011 | HP LaserJet 4200 Printer
Locked up apple G4 laptop
Hello, 3 audible beeps at startup means that you have a bad memory (RAM) install. Please try to unistall your RAMs the one after another
May 26, 2009 | Apple iBook G4 Mac Notebook
Garmin nuvi 650 isnt giving proper directions
Please see this link and determine if the internal speaker is bad.
http://www.sharc.net/gps_audio_repair.htm
- Jim
Nov 24, 2008 | Garmin nuvi 650 GPS Receiver
Gives bad directions
Have you completely removed power from the unit for a few minutes and then restored power to force a reboot ?
Aug 16, 2008 | Garmin StreetPilot 2610 GPS Receiver
SVC-1 Error Message
The only reset you can do on these is to unplug it for several hours and then plug it back in. This will reset the microprocessor .
This error could be many different problems and are usually not solved by resetting the machine. You may have a laser pick up, microprocessor that is bad, a memory ic bad, a voltage regulator bad. There is just no way to tell without troubleshooting it with the proper tools. Most error codes for this type of unit do not tell the service technician exactly what the problem is. It will only point them in the right direction.
Sorry this was not more help, but I have fixed a few of these with that same error code and it was different problems every time.
And please don't give me a bad rating for answering your question honestly. I have been repairing audio equipment for almost 18 years, I really do know what I am talking about.
I wish you luck, and hope that the reset works for you.
Let me know if I can be any more help to you.
Dave
Jun 30, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Bad Navigation
Try pressing the red/white little arrow looking buttons on the bottom right, that' flips the screen.
May 06, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Yamaha dv-s5650
I have a Yamaha DV-S5550 and recently did the same thing. Our players may have the same menu system. Give this a try. Turn the power to the dvd player on. Using the remote, follow this key sequence exactly. Press the onscreen button. Press the down directional key once. Press the right directional key once. Press the down directional key six times. Press the right directional key once. Press the down directional key once. Press the left directional key once. Press the onscreen button. Your player should now be set to NTSC output. Good luck!
Feb 24, 2008 | Yamaha DV-S5650 DVD Player
Tomtom ONE GPS Receiver Logo
80 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
