Question about Lynx L42PSR (NG) All-in-One Grill / Smoker
Ignition the ignition switch lights the prosear and the middle burner but not the left burner. The left burner can be lit with a match
  • 494 Answers
With the gas off, wait til it's getting somewhat dark out, and try the ignitor for the left burner and locate where it's sparking. If it's not positioned properly, or the wire has a short, it will not light the burner. Compare the ignitor positions for the other burners and adjust the sparking position as needed til it lights. Do not leave the gas on for more than 5 sec when trying to light it, so you don't have a build-up of gas and singe yourself.
Posted on May 15, 2010
Electronic ignition doesn't work anymore. How do I manually light this?
Before you go to match lighting, have you changed the battery in the ignitor button? If you haven't, I'd start there first. Unscrew the ignitor cap and the battery's Positive Tip (+) will be facing you. Be sure to install the new battery in the same direction.While the battery is out, check for any corrosion that may be present in the battery holder. A Q-Tip & WD40 work well to clean out any corrosion.
To match light the burners ... use a long stick match (also called a hearth match) and carefully guide the match between the grates and under the flame tamers, as close to each burner as possible. Of course, the match should be lit prior to doing this. Turn each burner on individually, as you place the lighted match next to it. Once the burner lights, turn it down to low and move to the next burner and so on, until all the burners you want to use are lit. Then set the flame heights where you want them.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 01, 2011 | Char-Broil Advantage 463453306
I CLEANED MY CANNON CARRICK COOKER TODAY AND NOW THE IGNITION WILL ONLY WORK ON THE TWO RIGHT HAND HOBS. OVEN ANG GRILL ARE FINE AND LEFT HAND HOBS CAN BE LIT WITH A MATCH.
More that likely your just got the cleaning solution you used on the igniter/in the burner. Light the burners with a match and let them burn for a little bit of time. This usually works. If not you might have to clean the igniter and make sure it is creating a spark for ignition.
Mar 07, 2011 | Ovens
The automatic ignition on my gas grill is not functioning. What's the alternative lighting method. A match?
YES, YOU CAN DO A MATCH.
BEFORE YOU LIGHT IT WITH A MATCH, REMOVE THE TOP GRILL TO
EXPOSE THE BURNER BELOW IT.
THIS WAY THE MATCH WHEN LIT AND THROWN IN WILL NOT GET STUCK IN THE
GRILL AREA WHILE THE GAS IS ON. THEN MORE GAS WILL BE IN THERE
BEFORE YOU GET ANOTHER MATCH LIT TO THROW IN. NEXT THING
YOU KNOW, THE MATCH DROPS DOWN IN BETWEEN THE GRILL AND
FINALLY MAKES THE BURNER AREA AND GOES 'BOOM'!
REMOVING THE TOP GRILL MAKES IT EASY TO TOSS THE MATCH
DOWN BY THE BURNER AFTER A FEW SECONDS WITHOUT A 'BOOM'.
TO FIX YOUR ELECTRONIC START BUTTON ON MOST UNITS, RE-POSITION
THE ARC UNIT IN THE BURNER AREA, TO BE CLOSER TO THE METAL IT ARCS TO.
IT IS MOST LIKELY VIBRATED AWAY FROM IT TO FAR AND THE ARC WILL NOT REACH
METAL OR GROUND TO MAKE AN ARC TO LIGHT THE GAS.
Feb 20, 2011 | Char-Broil Grilling
Left burner won't light with ignition, it will light with match
If each burner has its own igniter, you may need a new igniter. If both burners light off of one igniter, check the electrode to make sure there is a spark when you hit the igniter button.
Jul 09, 2010 | Ducane 1005A (LP) Grill
Rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
Jul 04, 2010 | Ducane 30400042 (LP)
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
The burner will not click to light but will work when lit with a
replace the ignition coil if no sound clicking,but the parts is expensive? is ok to use macht.
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
GEXL44 burners light with match, but not with electronic ignition
if u push the knob there is a clicking sound, if no the problem is damage the ignition coil, need to replace it,or check the outlet,plug or its batery operatet ignition? replace the batery.
the ignition is power operated,check the power source.
tnx gerbee
Jun 22, 2009 | GE Profile JGP636 Gas Cooktop
Hotpoint RGB745 Burner Problems- Unique, needs help
Not sure, but sounds like you may have a gas pressure problem or the stove is set-up for the wrong type of gas.
Apr 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Lynx L42PSR (NG) All-in-One Grill / Smoker Logo
169 people viewed this question
Top Lynx Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Lynx Grilling Expert? Answer questions, earn points and help others
