Question about Jenn-Air JES9800A Electric Kitchen Range
Jenn-air JES9800 error code F1-7
I have a error code F1-7.
Can you please help me??
Thank you in advance
  • 6 more comments
  • cloudycc Apr 22, 2008
    I have had same error since 4/8/08. Repairman replaced clock with harness #74009318, still has same beep and error F1-7 and F1-8. He has now ordered a new touchpad item #74005751, but the part won't be here for another week.
    (My stove is JDS9860AAW - gas burners with the electric oven "duel fuel")
  • Anonymous Aug 01, 2008
    What is the F9 solution?
  • Airy-Ka Aug 15, 2008
    called Jenn Air specialist (referred by help line) and the repair person was clueless. Charged me $70. and refused to answer my calls. Found another repair person who said it was humidity between motherboards. Now touch pad is gone (beeps continue) and I've no oven, downdraft or clock. No solution.
  • dsmith51200 Sep 13, 2008
    Normal 0
    I have Jenn-Air oven # JES9750AAW,I woke up to it beepingand it gave a code of F1-7. I ordered part #74007225 from ChicagoLiquidators at www.chicagoliquidators.com for$45.00 Brand new, everyone else is charging $155.00 to $206.00 for the samepart. Clock with Harness. It was very easy to change out, norepairman needed. It just plugs in.
    However I put the new computer part in, and it still gave the code ofF1-7. So I can tell people it most likely is not the computer when youget this code. It is something else.
  • markddrum Nov 16, 2008
    I have the same F1-7 problem. I have replaced the clock module but still the same problem. What's next, the touch pad?
  • magdy32 Feb 05, 2009
    Hi Just changed the timer on my jenn-air stove, and now it says on the screen F1-7. can you tell me what could be the problem?
  • cusenbary Feb 12, 2009
    I have the JES9800AB with error code F1-7. The repair guy said it would $900 to fix. That can't be right. The oven and range still work, it just beeps. Help
  • imtoib Mar 17, 2009
    I have the F1-7 error code. the stovetop works, but not the oven. What shall I do?
As indicated by others, the best solution for most people is to replace the touch pad assembly.
I went the cheap - time consuming route.
Jenn Air JES9800
Using the information from this forum and others I decided that the F1-7 error message was due to the touch pad. When I saw the price of the assembly which includes the touch pad I decided to take a look inside. With the power off :-) I disconnected the touch pad ribbon connector from the socket. Using a tool fabricated from a broken hacksaw blade hot bent 90 degrees about 4mm from the end, re-hardened and sharpened to form a knive edge, I carefully loosened the touch pad around the perimeter. The touch pad is applied to the frame with a flexible adhesive, so I was able to pull it off slowly without permanent deformation.
I softened the adhesive with odorless mineral spirits and was able to remove the adhesive from the touch pad with paper towels. upon examination of the touch pad I noticed several breaks in the the printed traces. I carefully pulled away the laminate near the breaks, which were near the flexible ribbon connector from the touch pad. I used a the copper powder paint from a Permatex rear window defogger repair kit to (tediously) paint traces to complete the gaps in the printed traces. The outer trace, which runs around the periphery of the pad kept showing a very high resistance (> 5 megohms) until I scraped away a short light colored section of the printed trace and replaced that with the repair paint. The trace then showed a resistance of just under 1meg. I temporarily re-attached the touch pad with tape and the error code did not reappear. I set the clock and successfully tested several buttons.
Next step - seal the area around the trace repairs so I can get some more years out of the stove, until the next repair.
The cause of this is an obvious design flaw. The printed traces were all compromised in the area where there is no discernable protection over the traces, allowing moisture (I assume) to react with the conductive material in the traces.
Posted on Jun 30, 2009
I have the same problem with the code F-7 FC. to fix the problem replace the
"touch pad and control panel assembly" the technical name Membrane. One or
more of the solid state trails are shorting out. It cost about $170.00.
Posted on Feb 15, 2009
  • 3 Answers
I got an f1 code in addition to a f9 ..Check out the f9 solution ..it worked for me..joe
Posted on May 28, 2008
Jenn air stove door is in the lock position and f-3 is in the display. Fan keeps cutting off and on but door will not open. Glass top burners work fine. Any solutions?
Posted on Nov 07, 2010
How do I find the part number for the touch pad of JES9800?
What color is your range? This site, http://www.appliancepartspros.com/search.aspx?model=jes9800&page=2 , lists several control panel assemblies (black, white, chrome) for the JES9800 . Click on the one matches and you'll see the part number. A parts diagram is also available. The number section of the touch pad is not sold separately.
I hope this helps.
(note: the part will have a Whirlpool part number. Jenn-Air is part of the same company and they use the same parts across all of their ranges.)
Aug 19, 2014 | Kitchen Ranges
Continuous beeping with F7 fault code. What do i need to replace, the touch pad or controller?
Hello, Thank You for using FixYa. I will be helping you today.Turn off power unplug ribbon cable from touch pad to control turn power back on and if after an hour no error code replace touch membrane if you get a fault replace control (clock Erc)
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Jenn-Air Ovens
Jenn-Air JDS9860AAW Touchpad display error F-7
Hello, Thank You for using FixYa. I will be helping you today.Its a problem with th touch membrane. These had allot of issues with this. Sometimes just unplugging and plugging the ribbon cable from the control to the touch-pad a few times fixed the issue. I would try that first.
Jun 16, 2011 | Jenn-Air JGS8850ADS Gas Kitchen Range
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
We own a JES9800 model of the Jenn-Air Oven. The
Then oad itself is flty and will have to be replaced. Yo ucan get one at repairclinic.com or partselect.com to purchase your touchpad and the manual, diagrams and whatever else you want for it.
Nov 18, 2009 | Televison & Video
How do you reset the clock
turn off probe light and beeping noise on Jennaire JES9800 how can I fix this
Nov 02, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-air ove3n flashing a error FR
hi friend,
error:FR
condition:second oven error sensed
resolution:1.check oven temperature sensor and hardness[or]
2.replace second board
hope this helps u
thank u for using fixya
please rate me....................
regards
sivaranjini
Sep 14, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Manuel - User's Guide
I'm not sure if this will help or not, but the manual number is 12828144A.
I recently purchased the same jen air model and have a problem with everything that is in the vegetable and fruit drawers freezing solid! Does you mother have the same issue?
Jul 24, 2008 | Jenn-Air Refrigerators
Jenn-Air JES9800A Electric Kitchen Range Logo
5,731 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
