Question about Samsung WEP475 Bluetooth Headset
How do I get my Samsung WEP475 bluetooth to notify me when receiving incoming calls? I hear a beep when calls disconnect, but silence when I am receiving calls
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,001 Answers
  • Smooth call conversation and non-stop and clear music streaming creates enjoyable listening experience
  • Universal Compatibility: Fully compatible with iPhone, iPod, iPad, Tablets, Other Smartphone, most speakers, TV, and radio, easily plugs into any powered PC speakers, Car & Home Stereo Sound System.
  • Small and Simple: Its outline feels like a mini iPhone 6, petite and charming, it doesn't need much space in your car; Simple design, easy operation, you can get away from complicated operation of some other Bluetooth receivers.
  • Charm sonic bluetooth audio receiver into your car AUX port or home stereo sound system,then you can enjoy your music time.
Amazon com Charm sonic Wireless CSR4 0 Portable Bluetooth Receiver...
Posted on Jan 06, 2017
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 17 Answers
It make a higher piched bbep when reciving calls. reference wit company
Posted on May 13, 2010
How do i enable incoming calls in my phone?
One or more of the following problems may be there
1. Check if it is on silence mode. 2. Check network setting and switch between line 1 and line 2 , 3. If the caller can hear ringing tone then the problem is with your phone. 4. try the sim in other phone if it does not receive calls then contact operator/customer care 5. Put a different SIM in your phone if you can, then also, not receive calls then try factory reset of your mobile.
Thanks
Jun 06, 2014 | Cell Phones
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
User has a iCom Bluetooth Hearing Aid adapter paired with her Plantronics Voyager 500A base station on a Cisco 7940. When on an active call and she receives another incomming call, her current call is...
Make sure that the Plantronics 500A base inteli-sensor switch is set to the number one setting (should be set on the one line, not the two line setting, on the right side of the 500A base unit). Also if you are using an EHS (Electronic Hook Switch) instead of an HL10 Handset Lifter, that could be the issue as well. The only other thing is to check the user guide for the hearing aid and make sure that there is not an "auto answer" setting that may need to be turned off. Here is a link below for the 500A / 510S user guide.
Plantronics 500A/510S User's Guide
Good luck from Headsets Direct!
Apr 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Cannot hear phone ringing in headset, only on handset.
The HL10 handset lifer is what notifies your headset that you have an incoming call. If you are using the handset lifter and are not receiving the 3 short beeps in your ear piece there are a couple different things that could be going on.
1. The internal microphone could have gone out on the lifter. This microphone is what sends the signal to your headset that you have an incoming call. If the microphone is working you will hear 3 short beeps in your headset.
2. If the volume is too low on your telephone, the handset lifter will not notify the headset of an incoming call, so try turning the volume up on your phone and see if that takes care of the problem.
3. The HL10 handset lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. This ring detector is intended for phones that do not have the speaker located under the handset. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help pick up the sound of the phones ring tone.
If you are manually lifting your handset out of the cradle and sitting it to the side instead of using a lifter, then you will not receive the 3 short beeps in your earpiece to notify you of an incoming call.
Nov 03, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Incoming call probem on samsung handset
7-9. Receiver Part
D813, D814 = 1.5V? Resolder UCP200 or change PBA
Receiver does not work
SPK800 +,- PAD = 1.5V? Resolder UCP200 or change PBA
Is Receiver working? Replace the Receiver
Check the soldering of the
Receiver contacts
Modify the receiver FPCB soldering
Jul 16, 2008 | Samsung D840 Cellular Phone
No 3 beep notification in the earpiece of an incoming call
I had the same problem and the cause was the handset lifter and not the earpiece--if the ringtone is too low at the lifter, it won't be detected and transmitted to the earpiece. Cranked up the ringtone and everything is fine.
If that doesn't take care of the problem you might look at whether or not you're using custom ringtones which might cause a problem. Switch them back to the defaults and see if the problem goes away.
Nov 28, 2007 | Plantronics CS70 Wireless Headset
I cant hear anything out of my headset
Is the headset paired and connected to your phone? Is bluetooth turned on in your phone? Look for the bluetooth icon on top of your phone's screen. Let me know what model phone you have and I can help you troubleshoot.
Sep 03, 2007 | Motorola Mobility H700 Wireless Headset
Samsung WEP475 Bluetooth Headset Logo
358 people viewed this question
Top Samsung Radio Communications Experts
JP Services
JP Services
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
