No there not connected, replace the brake light
1999 Chevrolet Blazer Auto Light Bulb Size Guide
Low Beam Headlight Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880 or 881
License Plate Light Bulb Size: 194
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 161
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168 or 211-2
Step/Courtesy Light Bulb Size: 168 or 211-2
Trunk/Cargo Area Light Bulb Size: 211-2
Under Hood Light Bulb Size: 93
Instrument-General Light Bulb Size: 161 or 37 or PC194 or PC74
Check Engine Indicator Light Bulb Size: PC74
Hi-Beam Indicator Light Bulb Size: PC74
Seat Belt Indicator Light Bulb Size: PC194
Brake Warning Light Bulb Size: PC74
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: PC74
As for the horn, inspect the fuse and relay and most common it would be a bad ground wire or worst a bad horn due to corrosion. Horn will be located in the drivers side fender.
Thank you for using fixya.
thx for a reply but, it's not the light,,it's in the wiring and the horn will NOT work at all, the guys checked it out and tell me it's a multi function switch at an outrageous cost and I need it fixed to pass the safety for my new playes and sticker.
It seems like you might be dealing with an issue related to the multi-function switch on your 1999 Chevy Blazer. To get a better understanding and find out the cost of a new one, I recommend reaching out to RockAuto customer service . They can provide you with the necessary information and assistance to ensure your brake light and horn are back in working order. Good luck with your repairs!
