E9 error on NEC washing machine
What is E9 error on NEC washing machineand how do I fix it?
SOURCE: washe machine problem
In other Daewoo models E9 error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes. It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor. It is often clogs with soap and other particles. Good Luck!
Posted on Sep 16, 2007
  • 15 Answers
SOURCE: E9 error means what
there is an error no 9
Posted on Jun 25, 2008
IrishDruid
  • 2712 Answers
SOURCE: NEC NW-491 washing machine. I
This usually indicates a problem with the water pressure sensor or the water level switch. A defect--or an obstruction--in the water-level switch may cause this issue. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open
Posted on Sep 28, 2008
SOURCE: dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Posted on Jan 11, 2009
SOURCE: NEC washing machine displays E9
fault code e9 relates to pressure sensor.
check connections or replce pressure sensor
Posted on Jan 23, 2009
E9 DISPLAYED IN WASHING MACHINE DAEOO MODEL DWF320LR WHAT IS THE PROBLEM
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
Jun 01, 2017 | Washing Machines
Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
Feb 09, 2015 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
Apr 25, 2014 | Washing Machines
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
My washer is showing error 20 and will not spin the water out.
Either drain is clogged or pump is jammed or faulty.
Clear drain and screen. Check pump for jams. Make sure there is power going to pump with a voltmeter.
If you have any other questions, feel free to ask.
Here are some diagrams, tips, and more if you need them.
www.repairclinic.com/RepairHelp/RepairHelp.aspx
www.acmehowto.com/howto/appliance/washer/washer.php
home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Oct 29, 2009 | Frigidaire ATF6000ES Front Load Washer
NEC NW 892 Errror E9
This error is related to the pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
Aug 01, 2009 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Jan 13, 2009 | Washing Machines
Apr 29, 2008 | Washing Machines
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
