Brother HL-2040 Laser Printer Logo
Posted on May 13, 2010
Corona cleaning does not solve error message
My toner light is flashing and pop up message recommends cleaning corona wire....and placing cleaning tab in the proper location to the right.. corona cleaning does not solve error message (after replacing toner). What other problem could I have. It is a new brother toner and printer is one year old.
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on May 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
Helped
3407
Points
25
You will need to replace the drum unit on the printer.
Printer keeps saying to clean the corona wire. I cleaned it several times but the message keeps popping up.
To clean the corona wire in the brother laser printer, it said to remove the drum/toner assembly from the printer. This is very easy to do, you simply pull down the front of the printer, and press a small green tab down and pull. Then the toner and drum assembly will quickly come out.
After that, it says you must clean the corona wire by moving a small green square back and forth several times. It seemed kind of strange to me, but I did it anyways. In the upper right corner of the drum/toner assembly, there is a small green/blue square that can be moved back and forth. I did this several times.
I then placed the unit inside, and the error message went away for a minute. However it still wouldn't print and the error message came right back up. I was a bit frustrated since I have only owned this printer for about 2-3 months.
But then I realized something: The toner button had been blinking for about a month. I had already purchased a high yield black toner cartridge for the brother laser printer (Tn-330/TN360). I purchased it online, and had it stored for when I eventually ran out of toner.
I thought perhaps the error message had something to do with the old toner. Maybe it was out?? So I once again opened the front of the laser printer, and removed the toner/drum assembly. I pressed a green tab, removed the old toner, and then added the brand new high yield black laser toner cartridge. The whole process was very simple (you gotta love today's technology).
I then quickly "cleaned the corona wire" a few times again just to be safe. I re-installed the toner, and the printer was up and running. So apparently it will throw this error when you are out of toner. Now the printer is running great again, and I really like this printer.
If you are still using an ink jet printer, then you are living in the stone age. I was reluctant to buy a new laser printer, but now I love it. The toner only costs $30-60 and lasts for months. I print hundreds of labels out each month-just to give you an idea of how long it lasts.or get more information Call +877 889 6859 for detail.
Says drum error, see troubleshooting maitainance chapter in user guide. Don't have a users guide. Printer is brother mfc-7340
I have this manual for you. I can be reached at [email protected]
http://welcome.solutions.brother.com/bsc/public/as/as_ot/en/doc/manual_index.html?reg=as&type2=-1&prod=mfc7340_us_as&c=as_ot&lang=en&flang=all
Drum Error - The corona wire on the drum unit needs to be cleaned.
Clean the corona wire on the drum unit. (See Cleaning the corona wire on page 122.)
Cleaning the corona wire: If you have print quality problems, clean the
corona wire as follows:
a. Turn off the machine's power switch.
Unplug the telephone line cord first, disconnect all cables, and then unplug
the power cord from the AC power outlet.
b. Open the front cover.
c. Slowly take out the drum unit and toner cartridge assembly.
CAUTION: We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
To prevent damage to the machine caused by static electricity, DO NOT touch the electrodes shown in the illustration.
d. Clean the corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times.
CAUTION: Be sure to return the green tab to the home position (a) (1). If you do not, printed pages may have a vertical stripe.
e. Put the drum unit and toner cartridge assembly back in the machine.
f. Close the front cover.
g. Plug the machine's power cord back into the AC power outlet first, and then reconnect all cables and telephone line cord. Turn on the machine's power switch.
I have a brother 2140 printer, it ran out of toner and i refilled toner starter cartridge , and error message comes back to clean the corona , i replaced ther cartridge with a new tn-360 cartridge, but...
When it says to clean the corona, on the drum there is a purple tab that moves from one side to the other. run it back and forth a couple times that should solve the problem.
I dont recommend refilling the cartridges, we have had several issues in repairing those printers with refill. if you must use refills, i would recommend getting 2nd or 3rd party manufacturers.
if you need help, you can contact us.
thanks adi
4helpful
2answers
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
35helpful
2answers
Drum error keeps popping up, cleaned the corona wire and changed the toner.. still flashing. what now?
Hi, Sorry my english is poor, but i will try: you have to say to your machine that you change the drum, open the front end, and pull out the drum , and insert it, but before you close the front end, push the clear/back button, and answer yes,...thi is it :-)
Yvon
1helpful
2answers
How do we clean the drum
from the brother website...
Description of Problem 100000015035
How do I clear the message PLS CLEAN DRUM from the display?
Description of Solution 200000019400
Dust or toner on the corona wire may cause this error message to appear on the display. To clean the corona wire, follow the instructions listedbelow.
NOTE: Brother strongly recommends that customers do not use generic drumunits and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
1. Open the front cover (below the paper ejection tray) by pulling the taps on the left and right side of the unit towards you.
2. Lift the drum unit slightly and pull it out.
3. Place the drum unit on a drop cloth or large piece of disposable paper to avoid spilling and scattering the toner.
4. Clean the corona wire inside the drum by gently sliding the blue tap (located on the top left side of the drum unit) from side to side 7 or 8
times.
5. Return the tab to the home position (left side of drum). It should click into place. NOTE: If the tab is not at the Home position, printedpages may have vertical stripes.
6. Reinstall the drum unit.
7. Close the front cover, pressing firmly on each side until the cover clicks into place.
3helpful
2answers
Corona wire needs adjusting
Of you need to remove the toner cartage the if you look on the roller side of it you will see a tiny yellow tab on the right side I believe that is the corona wire cleaning tab. You press down or hold on to it and slide it back and forth left to right thus cleaning the corona wire.
Also the message corona wire needs cleaning often is displayed close to the end of the toner life so after cleaning and reseating the toner back in the printer wait for it to self test 10 sec or so and the press three times the blue large (only) button on the printer. You need to press it at a good speed for the printer to respond. Press to fast it won't work.
This will give you a printer setting page on it the toner life will be displayed along with estimated drum life and good deal of other information.
Alarm is flashing, LED reads install Cartridge but the cartridge is installed. Any suggestions? Yes it is the right cartridge and I have tried replacing it with a new one, same error message
You've most likely got a dirty corona wire and/or drum. The wire should be cleaned each time you change the toner as well as if/when the print quality starts to degrage. Remove the toner cartridge, give the corona wire several swipes with the tab and make sure the tab is put back securely in place. If cleaning the wire doesn't fix your problem, go ahead and clean the drum. Either one of these or both should solve your issue. Only other thing that could cause your error would be the toner cartridge is not securely in place. (shouild click in securely). Best of luck.
14helpful
8answers
Corona wire AND MORE SPAM 1-800-975-0148
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
4helpful
Pls Clean Drum
The drum is the larger plastic unit that slides out an the toner cartridge fits into it. The corona wire is the very fine wire at the front top of the drum. Just slide the little cleaning tab back and forth.
Norman Weimar
Norman Weimar
k24674
