Question about Canon BubbleJet i560 InkJet Printer
My canon i560 printer cable is a 25 pin connector , my HP Pavillion a1630n does not have where to plug the connector in the back. What do I do?
If the 25 pin cable is centronics or paralell you're in trouble scrap the printer. if its a serial cable purchase an 25 to 9 pin serial adapter. your pc should have a 9 pin serial interface.
Posted on May 13, 2010
My computer...... an HP Pavillion a1630n..... was on this morning and I was working on it but the printer was not printing. I shut the computer down thinking it was just a glitch. However, when I pushed...
Behind every operation you do there is always an update that goes along with it. If you can re-open your computer and remove the power supply connector wait till 30 seconds and then reconnect the connector it will reset the motherboard for a moment and to sustain is to shut down the computer after the Windows Update completes the update on your system. A glitch will only happen when the system runs out of resources and then dumps everything into memory. If there is space in the memory then if not then it will crash definitely.
Jun 06, 2011 | HP Pavilion a1630n PC Desktop
How to connect printer in computer
Plug the printer into power from wall. Turn it on. Then Connect the USB cable first into the printer and then into the USB port of your computer. Now install the drivers for the printer. The drivers can be found either on the disk that came with your printer or on www.hp.com
Take Care!
damnor01
May 25, 2011 | Canon LASER SHOT LBP-2900 Printer
Canon i560 yellow light blinks 5 times. How do I clear it and have good printer again?
This is a printhead/cartridge error.
First try to reset the computer:
Resetting the PrinterBy resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur.Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
If that doesn't work try to reseat the printhead.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i560_series#ServiceAndSupport
Feb 20, 2011 | Canon BubbleJet i560 InkJet Printer
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
Can I connect my HP laserjet 5p with a 25 pin connector to my laptop which only has USB connection
On the back of the printer where the cable connects is actually a 36 pin connector, the end going to the computer is the 25pin end. What you will need to do is get a USB to parallel cable, they run $15-25, this will have the USB plug on one end and the 36pin centronix printer connection on the other end. This cable will allow your printer to be connected to the laptop. Office Depot and Staples should have the cable you need, if not you can do a google search for it and order one online.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | HP LaserJet 5p Printer
I have a hp pavillion dv4 1225 dx , my display is really bad , like almost gone, i would like to back up my documents before shipping laptop to hp for repairs, so i was thinking of connecting an external...
You can connect any HDMI or VGA (15 pin) compatible monitor or TV, almost every monitor has VGA connector or VGA adapter at the end of connector and you can use it.
Sep 28, 2009 | HP NB199UA Pavilion Notebook
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Paper jam
OK, first try resetting th printer. This sometimes works the first time and corrects a lot of issues. Switch it off, take out all paper, check for jams with a torch right down back and open cover and check ther too. Once you are sure there are no paper jams (look really carefully they can be tiny!) unplug all cords and cables. Plug all back in turn it on, and try printing again. Post back if no luck and i will further assist.
Mar 16, 2007 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
158 people viewed this question
old marine
old marine
