Convert to 220v krell amplifier ksa-250 - Audio Players & Recorders
  • 185 Answers
If it is conertable to 120v there will be a tap on the transformer input for that
Posted on May 27, 2010
Where can I get a fuse for my Krell KSA 300 amplifier.I had a blown fuse on the left channel.
Fuses rarely go on their own. The cause is likely to be a shorted semiconductor device in the left channel output.
Fuses are generally not specific to any brand. Is the fuse a tube with metal ends? If it is measure the length in MM. Then look at the end and you should see the rating. Either in A for Amps or MA for milliamps.
Any electronic parts supplier should have the one you want in stock. Buy several, for if the part I mentioned has gone, it will blow again.
Sep 09, 2016 | Krell Audio Players & Recorders
Hi, my Krell KSA 150amp is running cool any suggestions as to why. Many thanks
Audio output section circuit draws enormous current at idle stage. Contact any service electrician to detect the fault and get it repaired. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Mar 31, 2014 | Krell Audio Players & Recorders
Crackling noise all channel when i change 110v to 220v
Sound as if you have a low voltage, check for 220 v if its ok, then you have a current problem, the higher the voltage, it will be less current flow. Hope its not a flaw on the 220 v side
Dec 20, 2013 | Krell Showcase 5 5-Channel Amplifier
Hi, Will the krell kav 500i work on 220v 50hz supply? Thanks
If it has a voltage selector for 220v, once configured it will work just fine Being electronic instead of mechanical the power frequency won't affect it. If it doesn't have a voltage selctor, don't plug it into 220.
Dec 26, 2009 | Krell Audio Players & Recorders
Krell kav300i, increasing volume by itself.
That is an extremely odd problem. I suggest finding a tech in your area who is familiar with the unit, or contacting krell directly.
Sep 21, 2008 | Krell KAV-300i 2-Channel Amplifier
Krell 250a power amp
Hi There WLAW,
I am in Auckland NZ and do repair work for a high quality Amplifier chain so I could have a look at yours for you....
Being Local in Auckland it will save you sending it away off shore to Australia.
Cheers From YUBEUT (09) 357 7496
Dec 26, 2007 | Krell Home Theater Standard 7.1...
249 people viewed this question
 Grubhead
Grubhead
