Question about Panasonic WORKiO DP-C262 Printer
Microcode fails to load at power on self test (post). stays on WorkIO splash screen as the hard drive fails sounds like it crashed or is stuck ina loop.
The microcode is loaded from CMOS not the hard drive. CMOS also sets up the 40Gb. hard drive for use. Initially has no data or partition tables however; post will not complete if the disk is unavailable. Replace the disk drive and you're Done!
Posted on May 13, 2010
Failing to load up now after crashing. Gave run series of tests and it mentions something of the hard drive My laptop is not the notebook tho
Run Dell diagnostics to see if your hard drive is faulty.
Connect power cable, turn on laptop and press F12 key when the Dell logo comes up.
Select Diagnostics and hit enter, if you get the windows splash screen, turn off laptop and repeat.
Feb 10, 2011 | Dell Inspiron 1545 Notebook
Hard drive crashed
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer.
  1. Plug the AC Adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  5. Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
NOTE:
The exact wording of the option for your particular BIOS may be slightly different.
The Hard Drive Self Test performs a Quick Test followed by a Comprehensive Test . During each test, the window displays a status bar and an estimated time to completion. See HP Notebook PCs - Testing a Hard Disk using the Built in Self Test for additional information.
  • If any test fails , contact HP service and support for instructions on how to order a replacement hard drive.
  • If all of the tests pass, the hard drive is not damaged. As a rule, HP will not replace a hard drive under warranty that does not fail the HP Hard Drive Self Test.
  • If there is no physical problem with the hard drive or memory, then try reinstalling your Windows operating system to troubleshoot the problem.
If it fails then you need to replace the HDD. If you can provide me the product no. then I would be able to find the exact part no.of the HDD.
Dreamkam
May 28, 2010 | HP Pavilion dv1000 Notebook
My 7Y250MO hard drive starts clicking and after a few seconds the system locks up only fixed by powering down and restarting.
Try doing the self-test for the hard drive. It could be a sign of hard drive failure. Just boot to BIOS go under diagnostics then select Primary Hard-drive Self Test. In hp notebooks, we use f10 after turning it on to boot into bios. Ask your computer manufacturer how to boot to BIOS. If you're Hard drive passed the test you might want to try re-installing the operating system. It could be a sign of Windows crashing. If you're Hard drive failed. There you go. You have to replace the hard drive. Hope this helps.
Mar 07, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
My laptop is a dell 6000 and it says there are no bootable devices
your hard drive has failed, on boot (dell splash screen) press f12 to bring up boot menu, choose diagnostics option, run this and it should confirm hard drive failure on dst short test (drive self test) and give an error code (e.g 2000 - 0142), trust me on this i am a dell field service engineer
Jan 14, 2010 | Dell Inspiron 1525 Notebook
Screen went black...rebooted, computer seems to
Remove the battery and disconnect the power adapter for about a minute.
connect only the AC then boot it back up. If you can see the Compaq splash screen and still unable to load Windows, re install OS.
If you could not see the splash screen, too bad it could be a motherboard issue,
Hope this helps.
Dec 21, 2009 | Compaq Presario CQ60-220US PC Laptop
HP530 shuts down within 15 seconds as it loads XP
Probabpy an XP problem, start XP in safe mode (press F8) as it is loading.
If it runs then it is probably a driver problem. Try restarting in the last good configuration. Keep posting until the problem is resolved.
Aug 17, 2009 | HP Computers & Internet
ASUS Splash Screen Stays on at Post....
AFAIK splash screens are generally controlled in your CMOS settings, you'll need to hit DEL on POST (Power On Self Test) alternatively called a 'boot up' to access your CMOS panel.
Jan 19, 2009 | ASUS Computers & Internet
On boot up screen reads "Loading PBR 2...done"
As the notebook is starting you see the Dell 'Splash' screen. Press F2 to go into the BIOS setup. Check to make sure two things: first that your cd/dvd and hard drive are being recognized and identified, second that your boot order has the cd/dvd first and internal hard drive second. Your machine may be trying to do a USB device boot or network boot when these options are not available. Next try pressing F8 immediately after the splash screen disappears to try to get into Safe Mode. If it still fails to boot, I would try booting using a Windows XP installation disk and then going into the repair console to check if the hard drive is damaged or corrupted.
Dec 15, 2008 | Dell Inspiron 6000 Notebook
Power On / No Boot
Is it POSTing? Do parts make noise and then theres a Beep? The beep means it finished the Power On Self Test. Once it posts then it will show splash screen or black screen with it testing hard drives disk drives etc.. If no post is the led lit that says A/C is connected? before you attempt to turn on? If no post and good ac to rear connector then you probably need a new motherboard.
James Mac
Aug 31, 2008 | Acer TravelMate 2300 Notebook
#1-07 Fail
looks like hard drive problems or missing operative sistem so you can run a test boot up your computer in save mode when the computer try to restart press the key F8 and click on save mode if you can acces into it means you have problem with your software if not you have bad hard drive
Dec 31, 2007 | HP Compaq Business Notebook NX9010
Panasonic WORKiO DP-C262 Printer Logo
107 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
