Question about Coldtech J4SRF-40B Commercial Refrigerator
Lost 3 compressors in 6 months ran for 40 months problem free
Lost 3 compressors in 6 months ran for 40 months with no problems. severe knocking prior to failures
    Guru:
  • 1,524 Answers
Was expansion valve changed ? A bad expansion valve would let liquid refrigerant flood back to the compressor hence the knocking.
Posted on May 13, 2010
Will bad knock sensor stop ignition from sparking?
I'm going way back into my alcohol erased memory on this one, but check your oil level sender. I ran into this problem many years ago and it seems like that was the culprit.
Feb 19, 2016 | 1993 GMC Sierra K1500
Thero. knocks off
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Replace both thermostats. One or the other is sticking, and there is no way to test which one is bad... since test unsticks a stuck thermostat
Gene
Jul 01, 2014 | Reliance 606 Series 40 Gallon Electric...
Air compressor makes loud knocking nois when running
remove shroud and see if fan is broken but may be piston is shot
Apr 10, 2013 | Craftsman 33 gal Air Compressor 6 hp...
We have an 11 year old fisher-paykel fridge .For past 6 months several times a day it makes a loud knocking noise
If this noise happens when the compressor turns on and shuts off it is called a compressor knock. All the internal workings of the compressor are supported by springs, over time the springs wear out and become weak. When the compressor stops or starts the tourq causes the internal parts to hit aginst the casing of the compressor. Sounds like a clunk clunk clunk noise. If you can deal with the noise do not go out and replace the compressor cause it will work just fine like that.
Sep 01, 2011 | Refrigerators
Lost the voice on channels 17 and 7 only. All others are fine.
iF YOU ARE RUNNING THIS WITH A ANTENNA THEN IT IS JUST LOW SIGNAL, TRY A 25DB AMP TO FIX IT. sHOULD COST $15-20
Jun 07, 2010 | Toshiba 40RV525U 40 in. LCD TV
I had to change the compressor of my 2 ton bio-sleep split AC from samsung (6 months old- but stopped working at 5 months). Now when the ac is powered on the compressor starts instantly, without the 3...
I would say control board. Get on Samsung web site and go to technical support and get there 800 number. I have called several times and they can walk you thru it. Just have your m They model number handy. They can also tell you wether you need a service tech or not. Be sure to ask for free estimate. Rus
Nov 09, 2009 | Samsung AW0503B Air Conditioner
2001 H-D Road King engine knock
For valve train noise try these:
1. Low oil pressure caused by oil feed pump not functioning
properly or oil passages obstructed.
2. Faulty hydraulic lifter(s).
3. Bent push rod(s).
4. Incorrect push rod length.
5. Rocker arm binding on shaft.
6. Valve sticking in guide.
7. Chain tensioning spring or shoe worn.
8. Cam(s), cam gear(s) or cam bushing(s) worn.
9. Cam timing incorrect.
If it is a bottom end knock, an engine tear down may be in order.
May 30, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
Air compressor trips breaker
check the ground wire most common mistake
Nov 18, 2008 | Air Tools & Compressors
Coldtech J4SRF-40B Commercial Refrigerator Logo
126 people viewed this question
Top Coldtech Refrigerators Experts
Dan Webster
Dan Webster
Randy Justice
billconfused
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
