Question about Health & Beauty
Aspire m-11 has erradic light flashing and occasionally chair will lurch fwd. the joystick receives light input but chair will lurch. has orig. 3 y.o. batt.'s whatta ya think??
  • 177 Answers
Hi. Lights flashing is sometimes a fault code. Count the flashes. Sometimes The lurching is caused by the motor brushes jaming or bouncing in the motor. I caused the motor to stop and start erratically. Usually happens in machines that have done a lot of use. Get a serviceman to inspect the brushes and see if they are worn down or have been jaming in the brush holders.
Check all the plugs and connectors including the motor and battery connectors. I have replaced a lot of battery and motor connections because they cause intermitent faults. Good luck. Neil.
Posted on May 29, 2010
Light flashes 7 times
7 Flashes indicates a joystick trip. Turn off your chair, ensure the joystick is in center position without anything touching it and turn on chair. This should clear the 7 flash code.
This problem is quite common amongst power chair users. It typically occurs when something is pressing against the joystick as you are turning the chair on.
Feb 14, 2014 | Select Jazzy Used Electric Wheelchair
My mom has a Aspire M11 Quickie Power Chair. Today, out of the blue she was sitting in front of the TV and the power indicator lights start flashing and the chair would not move. We have tried charging...
Check to see that both motors are in the "engage" position. If they are, the problem could be in the joystick, or the communications cable between the joystick and the controller. If you can't find the problem, call your dealer and tell them how many lights are flashing. This will give them a better idea of what's going on. Good Luck!
Sep 05, 2011 | Health & Beauty
I JUST PURCHASED A JAZZY WHEEL CHAIR AND IT IS I THINK 2003 MODEL WHEN TURNED ON THERE ARE 3 RED LIGHTS AND 4 YELLOW LIGHTS FLASHING AND NOTHING HAPPENS
the 7 lights indicate a joystick problem which means the joystick/controller will have to be replaced since there is no self repair fix Unless you can locate a good used joystick/controller for cheap (around $600.00 rebuilt) I would return the chair and get my money back Hope this helps
Jun 20, 2011 | Pride Jazzy 1103 Ultra Standard Power...
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
How do I know if my jet 3 ultra is charging? I just bought a used one today and do not have a manual
The chair should have a meter on the rear panel where the 9 pin connector for the joystick plugs into the chair when you plug in the charger cord the meter should move up and the lights on the joystick should flash indicating the charger is plugged in. When the chair is fully charged the meter should read zero or bounce up and down. Hope this helps
Feb 02, 2011 | Jet 3 Ultra Power Chair
Jet 3 flashes "code 7".
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
Nov 30, 2010 | Jet 3 Ultra Power Chair
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Aug 12, 2010 | Pride Mobility Products New Pride Mobility...
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
Pride mobility Jet 3 Ultra Power Chair 7 flashing lights. joystick error. how do i fix ? Three red LEDs Four yellow LEDs
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. smithrmrm70@hotmail.com
Sep 06, 2009 | Jet 3 Ultra Power Chair
Health & Beauty Logo
53 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
