Question about Viking DMOC205 Microwave Oven
Microwave oven stopped heating. However, everything else is functional such as circular plate still turns and unit has full power. What could be the cause and solution?
  • Viking Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dgdj
Posted on Sep 30, 2010
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Our Kenmore microwave oven recently stopped heating. The lights, turning plate and controls all work but with no cooking is occurring. The last time I attempted to heat something up I heard a cracking...
The most likely cause is a bad magnetron, "heats food" the other two possibilities are the high voltage capacitor and diode. The cost to repair will a approach a new microwave oven.
Apr 08, 2011 | Kenmore 80412 Microwave Oven
Microwave stopped heating. Everything else still works - it comes on, the light comes on and the plate rotates and it dings when it done, but te food is still froozen.
Sounds like either the magnetron or its high voltage power source has failed.
It is extremely dangerous to work on the magnetron side of the power system. It CAN and DOES KILL!
Dec 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Oct 03, 2010 | Samsung Microwave Ovens
Turntable has stopped revolving... will start to spin as soon as START button hit - goes about half an inch and then completely stops.
One suggestion i would make is that in the microwave there is the turntable, lift the plate off ,then below it you will see a circular object with wheels on.I think you may have this the wrong way up, so turn it over put the plate back on top and should work.
its the circular piece on runners that is the problem
Oct 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
Viking DMOC205 Microwave Oven Logo
90 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
