Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Pump cycles like crazy!!
Hi there, i have a 3/4 hp jet pump at my cottage..drawing water from the lake, it cycle on and off very quickly...twice a second perhaps!
I've adjusted the electrical switch either direction, and the pressure in the tank..with no effect. There is a brass adjustment on the pump itself and it finally stops cycling if i turn it all the way in!! I'm thinking this isn't the real "fix"! Could it be the fact that the lake, although only 15-20ft drop..is about 200ft from the pump!?
I fill the suction line and the prime the pump so it has never been dry. It pumps water, but cycles like crazy! At any pressure i set it at...30.40 60.
It seems to be okay if i turn that brass adjuster all the way in...can i leave it in? I don't wanna screw up a pump or overlook an obvious problem.
PS everything is brand new..pump,tank,lines,filters,foot valve..with no change.
thanks very much
jamie
  • Randy Marshall May 13, 2010
    Watch your pressure gauge the brass screw may be a flow rate control? How many gpm will it pump , it should have a tag on pump itself.
  • olfartca1 May 13, 2010
    sadly i'm not at the cottage now, so i can't tell you how many gpm...but it seems like A LOT! When the screw is all the way in and the pump is pumping....there is a ton of volume!
  • 126 Answers
Sometimes a new tank the blatter will be kinda sealed to the sides of the tank.the amount of air in the tank s/b equal to the cut in pressure of the pressure switch.(40 lb) that would be (60 lb) cut out if you messed with the little screw on the pressure switch you have a problem.there must be the 20 psi of differance between start and stop.
Posted on May 17, 2010
Trying to connect pump at cottage but can't draw water
You need to prime the pump first. Poor some water into the outlet of the pump, so it enters the main chamber, then try again. These pumps cannot pump air.
May 21, 2012 | Plumbing
My pump loses pressure and I think the elect. control box needs to be re-set but there are two screw-nut controls and I,m not sure which one to turn and in what direction to adjust the on &...
those two screw nuts control the turn on pressure and the turn off. Under the cover of the switch should be a label identifying them. Turning them to the right increases the pressure
Jun 24, 2010 | Jet Plumbing
The message flo is showing on the display
THATS WHAT THESE DO IT WILL CYCLE AND KEEP THE WATER MOVING SO THERE ARE NO COLD SURPRISES WHEN YOU TURN THE JETS ON.. REMEMBER TO VOTE .. THANKS
Feb 14, 2010 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
New 1/2 hp jet pump with tank not working
Your hose size is to small. Use a 2in black plastic line out to the lake. Inspect your foot valve, and
take your pump apart to see if you may have a pebble stuck in it, and remove the inner workings
and clean. Contaminates build up inside and need to be flushed out. Remember to replace the
gasket. Tighten all your hose clamps. Once your ready to start, spray shaving cream on your
fittings to see if your sucking air. I've been through it all and my pump works fine.
Chuck
May 03, 2009 | Plumbing
I have a 1/2 hp jet pump that draws lake water. We have tried and tried to prime it and get it up to presure. I have replaced the foot value but when started it reaches 20 psi and waivers down to 5 then...
I have seen little critters (looks like baby clams) make a home inside the suction pipe and on the impeller in the pump. They can cause a lot of pressure problems with just a few of them in the way.
Jul 24, 2008 | Heating & Cooling
Water leaking out of water filter connector Maytag MSD2657HEB
HERE you will find all your answers as to parts etc follow the drawings and you know how to take it apart. Site takes a little to load
Apr 24, 2008 | Maytag MSD2656G Side by Side Refrigerator
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
279 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
