Question about Acer Aspire 5610 Notebook
Wifi disconnects The Atheros ar5007eg wifi disconnects about every minute. Operating system is Vista Acer Aspire 5610z. I fixed this once a long time ago but didn't document the fix. It is not the power save mode. That is disabled.
    President:
  • Acer Master
  • 1,118 Answers
I wonder if your router's encryption method is WPA or WPA2, and it is set to update its passwords periodically (like. every minute). If so, try to remove such action.
Just my 2 cents... Carlos
Posted on May 13, 2010
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
I have an Acer aspire 5610z Just acquired a Verizon MIFI2200 53CF Secure Ability to network 5 wireless computers Was able to configure below not problem IBM T60 Compaq Presario Not the case with...
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Go to your laptop, right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Aug 03, 2009 | Acer Computers & Internet
Acer Aspire 4315-how to fix atheros ar5007eg wireless network adapters that shows "!" in yellows
There are a few things you can try for the dreaded !
Delete and let it be discovered again or select it and try reinstalling the driver from the CD that came with the unit. Make sure the driver is compaitible with your operating system XP drivers wont work in Vista. You may need to get an updated driver from Acer to overcome this problem
Jul 28, 2009 | Acer Computers & Internet
Aspire 5100 will not connect to wireless network. -------------------------------------------------------------------------------- I am using an Acer Aspire 5100. I formatted both drives and reinstalled...
http://driverstock.com/Acer-Aspire-5100-driver-download/4-21-12867/index.html
so ..my advise is to reinstall the windows xp ...cause this machine it was on xp from the first ...and this might be just the reason ..those are the drivers for it
also ...you can download Everest software ...and locate the exact name of the wifi platform ..and look after that for a vista driver for it by its name ......this way you cant be wrong ...cause you locate the suitable driver ...not the ones they feed us in packages...
Jul 18, 2009 | Acer Aspire 5100 Notebook
Can't set up ethernet card
Hi there.
I have the solution for you but before i give you it are you familiar with source code and are you running Ubuntu?
Look forward to your reply.
May 20, 2009 | Acer Aspire 4315 Notebook
Web cam is not working
First remove the current driver from add/remove programs applet in Control Panel ,reboot and then reinstall the driver from the drivers CD or download it from Acer:
http://support.acer-euro.com/drivers/downloads_gd.html
Select Notebook ,Aspire ,then 5610z, by default the operating system is Windows Vista but you can change it if you have Windows XP.
Download the bison driver and reinstall it.
Apr 29, 2009 | Acer Aspire 5100 Notebook
I have a fujitsu siemens amilo li2727 , i can't connect wifi (carte atheros ar5007eg) under xp sp3
I might advised you to check the driver of the wireless adapter using your computer. There are some issue about the operating system like SP 3, Check the driver if it is compatible to the operating system.
Mar 09, 2009 | Computers & Internet
Netopia 2247 NWG can't find Atheros AR5007EG WLAN
ok heres the solution.
goto start,control panel,performance and maintainance,administrative tools,services.
Scroll down to bottom to WIRELESS ZERO CONFIG,double click and click start.
now exit and wait a minute and your limited or no connectivity should change to connected,
let me know if this helps,
Patrick.
Aug 02, 2008 | Netopia 2247NWG-VGx Wireless Router...
Connect to the internet
i look for driver Atheros AR5007EG wireless network adapter for acer aspire 5315
Jul 09, 2008 | Computers & Internet
Acer Aspire 5610 Notebook Logo
381 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
