Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
One CD door does not open
I have a Neumark CD mix 2 console - Its has not been used much over the last few years.
When we tried it out recently, we noticed that the left hand cd will not open when first switched on. Though strangely when you open the flap and blow into it a few times and then press the eject button it finally works. Then it carrys on working till you switch it off and leave it for a few hours then same problem occurs.
Sometimes it works first time if there is a cd left in.
Have you any ideas of what the problem may be?
Thanks.
Ang
    Genius:
  • 1,550 Answers
La banda del motor de carga de disco ya esta floja necesitas cambiarla.
Posted on Mar 29, 2008
SOURCE:
I need to know a fuel oil ratio.
Regardless of what the manual says once adjusted your saw will perform better with this mix.
Do you need bar oil? Available at any Hardware or Home Center.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Dec 27, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Craftsman 16'' 36cc's oil to fuel mixture, and bar oil requirements
Your Craftsman is probably a Poulan, for the past few years Poulan has recommended a 40:1 ratio 1 gal premium/3.2 oz quality 2-cycle engine oil. I'd thin down even a little more 50:1 (1 gal premium/2.6 oz quality 2-cycle engine
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
For the bar every home center and hardware sells bar oil. It is 30 weight non-detergent oil with a few additives to help it adhere where lubrication is needed. HTH
Lou
Nov 16, 2009 | Garden
What is the oil/gas ratio for this model chainsaw? I left my manual at our previous address. Thanks
Fuel/Oil Mixture
Lou
Nov 15, 2009 | Homelite Garden
Pb1000fuel to oil mix ratio for echo
New Echo manuals say "50:1 for all engines regardless of what is printed in manual."
Fuel/Oil Mixture
Lou
Nov 09, 2009 | Echo Garden
Does 2 cycle oil get mixed with gas on McCulloch chainsaw or just put gas in?
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 14, 2009 | McCulloch Garden
Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Gas / oil mix for craftsman chainsaw 36cc
Fuel/Oil Mixture
    Lou
Sep 26, 2009 | Garden
Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Stuck on a certain stage on God of War 1
U got stand on the first plate with the statue in front of u and then u should kick it to the other plate and then u should roll thru to the other side.
Aug 08, 2008 | Sony PlayStation 2 (PS2) Console
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
96 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
da surgen
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
