Question about Mitsubishi WS-65807 65" Rear Projection Television
Can I get 1080 resolution on all outputs - Mitsubishi WS-65807 65" Rear Projection Television
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
No, this model should only have one input and it will usually be marked DTV and in small letters at the connections say 480/1080.
SD TECH
Posted on May 13, 2010
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
My dell 32in LCD tv is showing an out of range error
sounds like your apple TV is putting out a higher resolution than your TV supports. Is the resolution on your tv 720 rather than the 1080 that the apple tv outputs. If that's the case go into the menu on the apple tv and change the output on the apple tv to 720.
Feb 02, 2014 | Dell W3201C 32 in. LCD Television
1080p tv stays in 480p mode
Resolution is a slave to the source. It sounds as though the source is only outputting 480p. Go through the menu settings of the source device(bluray, cable, satellite box, game system) and set it to output 1080.
Jul 10, 2012 | Toshiba REGZA 46RV530U 46-inch 1080p LCD...
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
Change dpi from 480 to 1080
to change the resolution you will need to change the source. So if it's a DVD player then you have to make sure it's outputting the higher resolution. If it's a cable box the same thing. also to get 1080 you need to have component or HDMI hooked up. If you need further assistance let me know.
thank you,
Lee
Jun 09, 2011 | Vizio L37 Television
How do I set my tv to 1080
You don't set your tv to 1080. You set whatever you are connecting to your television to 1080. Let's say it is a cable box or blu ray player. You would need to be connecting it to your television with an hdmi or component cable. Connect it only once to the television with an hdmi or component cable. This may sound ridiculous but there are people that have their devices connected to the television three times with three different types of cables (hdmi, component, composite) instead of just one. Make sure the television is on the proper input. Adjust the video output settings to reflect 1080 i or p if possible resolution.
Apr 07, 2011 | Polaroid 3211TLXB 32 in. LCD Television
My emachine t3624 can't get the 1920 x 1080 resolution for the e211h monitor
Your monitor is capable of that resolution, but your video card may not have enough memory or speed to provide a resolution of 1920 x 1080 x 32 bits of color @ 60 Hz (assuming that you are using the video output from your emachine's motherboard)
Your best bet is to buy a cheap video card that can give you that resolution.
Mar 30, 2010 | E-Machines eMachines Monitor E15T4
How to adjust from 480p to higher resolution up to 1080
several things use hdmi cabling, also change resolution (can sometimes be changed on front of direct tv receiver) or may have to go through menu to change to the different resolutions. also turn the native mode OFF! having the native mode on for directv will give sometimes give you odd pictures. also whatever resolution you choose through directv menu's make sure your tv is also set to the same resolution
Apr 04, 2009 | Televison & Video
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
