Question about Lexmark T644 Laser Printer
T644 won't print - message says "900.43 Service RIP Software" - What does that mean??
  • 150 Answers
It means the RIP board is bad. It's under the left side cover. I think the board is around 100.00 and easy to replace. Steven 805-520-3003
Posted on May 13, 2010
    Problem Solver:
  • 4 Answers
I have also seen that when printing some documents from Adobe, certain versions will cause problems with the printer printing them. Usually, if you update to the latest version of Adobe, this problem will stop. Otherwise, the problem is the system board.
Posted on Aug 11, 2010
5 Suggested Answers
  • 217 Answers
SOURCE: I am getting a message that says 900 Service RIP
This means there is a problem with the engine board. You can try to reset to factury defolds. Turn off the printer, push the buttons 2,3 and 5 and than turn on the printer. When message "reset to defolds" apears release the buttons. If this does not work than you have to exchange the engineboard.
Good luck, Gerrit Jan
Posted on Aug 12, 2009
Mrinny
  • 94 Answers
SOURCE: What does 900 Service RIP Software error message
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Posted on Aug 02, 2010
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
Posted on May 04, 2009
mary_sparkes
  • 25 Answers
SOURCE: I got message (900.00 service rip software) on my
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Posted on Nov 15, 2011
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
Sep 16, 2011 | Lexmark T644 Laser Printer
What does 900.00 rip software mean?
This means there is a problem in the software of the machine.
You can try resetting the factury defaults. Turn the machine off.
Press and hold > , v and V .
Turn on the printer.
Release the buttons when resetting defaults displays
If this doesn't help than replace the systemboard.
Jul 20, 2010 | Lexmark T644 Laser Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
I am getting a message that says 900 Service RIP software - what does that mean? I cannot print.... help??
Aug 10, 2009 | Lexmark Optra T610 Laser Printer
I have a problem with t644 indicated 900.00 service rip software before this error printer indicated 960 service.after turn printer off then on error code indicated immediatly
Try this...power off printer. Then if it is a network printer go the to print server and clear all the documents from the print cue. If it is a local printer clear all documents in the local print cue then power the printer back on. Once the printer powers up the error should clear, if it doesn't clear power the unit back off and ensure that all documents have been removed from the print cue then power printer back on. This worked for me on the C782e, x854e and x940e models that I have.
Jul 04, 2009 | Lexmark T644 Laser Printer
Dell M5200n printer will not print web pages, it will print from adobe, black and white pictures, and text documents. When printing from web page the lcd display says 900 service RIP software. I have...
i would recomend you downloading a fix file from dell.com you need a rip repair file at little or no cost.if you are running vista, i would recomend you get a new printer
Feb 26, 2009 | Lexmark T644 Laser Printer
I have a lexmark t644 printer and have an error code of 900.44 any ideas on how to fix this
  1. If the printer is currently displaying a 900 RIP Software error, power off the printer and leave it powered off for 20 seconds or more. Doing this will clear the printer's memory.
  2. While the printer is off, clear any pending print jobs from the computer or the network queue. This will prevent any corrupted print jobs from being sent to the printer again when it is powered back on.
  3. Power the printer back on.
  4. If the printer goes to the Ready status, try printing again.
  5. If the 900 RIP Software error returns when the printer is powered up or when you try to print, there is a problem with either the printer, the communication cable connecting the printer to the computer, or with the print job itself. Follow the directions below to check each of these components.
    • If the error appears every time you power on the printer, regardless of whether you send a print job or not, the likely source of the problem is the printer or an option installed on the printer.
    • If the error appears only when you send print jobs to the printer, the likely source of the problem is the computer, a setting on the printer, or one of the communication cables.
Nov 17, 2008 | Lexmark T644 Laser Printer
The printer Lexmark C532c is not printing.
Try using the PCL driver or select the "Disable Postscript Passthrough" under
Printing Preferences->Other Options->More Options->Postscript
Nov 12, 2008 | Lexmark T644 Laser Printer
T644
Disconnect network and power cables for a minute, connect them back, turn the printer back on.
Feb 19, 2008 | Lexmark T644 Laser Printer
Lexmark T644 Laser Printer Logo
3,185 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
