Question about Philips 37MF231D 37 in. LCD Television
Wont turn on
My flat screen tv will not turn on. the red light in left corner is flashing 7 times, any ideas? the screen was doing some weird stuff before hand like half ok and the other half blurred. nikolejules@aol.com nikole juliano
  • 11,896 Answers
The problem usually is from low quality or defective "capacitors" on the main circuit board. There are two capacitors in particular on the main board that causes problems with these tv's. You can check for swelled up capacitors or burn marks on the circuit board. You can also purchase an analog tester or ohmmeter and test the capacitors.
If for some reason these caps test to be ok, then test the power inverter.
Posted on May 13, 2010
The TV will not turn on. When the switch at the lower left corner is pressed the light in the switch flashs green for about 4 seconds as the TV seems to go through a start up procedure. Then the light...
The red flashing light is the service code. My guess is the power supply is bad now, but it could be something else. If the TV is under warranty, take it in and get if fixed. If it is not, then you may try to check the power supply first. Count the flashes of the red light and check online for the issues when this model flashes, 4 times or 6 times... or 9 times, etc.
Oct 10, 2010 | Panasonic TH-46PZ800U Plasma TV
Tv comes on, green light flashes several times, get the "digital television" shown at botton left corner, then flashing green light stops, tv turns off and red constant "stand by" light comes back on. TV...
common problem with that model is the backlight inverter, 1 or more of the six transformers may be bad.also check for bad capacitors.the tedious way to check is unplug each and plug in each one at a time but unplug the power from the tv each time you check one or you will get a nice jolt. the one that doesnt light the lamp is bad.or take each transformer off and check the primary and secondary coils if you find one open coil. the transformers cost between $8 and $20 each.it has a substitute part.
Jul 05, 2010 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
My tv will not come on. It flahses red 7 times.
u have 2 bad capacitor on power supply , they are very small ,
Apr 15, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
May 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
TV won't turn on and red light flashes 6 times.
MINE DID THAT AND IT WAS THE THERMOSTAT FOR THE BULB
Jul 14, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Philips 37MF231D 37 in. LCD Television Logo
323 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
