Question about Ricoh Aficio SPC210SF All-In-One Laser Printer
Constant paper jam at entrance to fusing roller after removal and reset
  • 150 Answers
Look at the leading edge of the paper that jams. Is there any damage or small bends. If yes something in that area must be blocking the paper and causing the jam. Look very close with a flash light. Also clean the feed rollers with a cloth with water 409 or fantastic NO alcohol. Steven 805-520-3003
Posted on May 13, 2010
Carriage jam on HP C4680 printer after putting in new ink cartridges
Have you checked to see if you have a paper jam in the back entrance of your printer. Make sure there are no pecies of paper jamed on the roller.
Jan 20, 2011 | HP C4680 All-In-One Inkjet Printer
Oki c810 printer is having constant paper jams and tray not feeding paper at all
Your paper is too smooth for the rubber rollers to grab it.
You need to wet the rubber rollers. Ever licked your finger in order to turn a page in a book? Same concept solution here.
Remove the paper tray. Take a look inside the space created where the tray was, and locate the rubber rollers. Lick your fingers, and use them to moisten the rubber rollers.
Reset printer and print again. Or try "un-smooth" the paper where the rollers grab it.
Oct 05, 2010 | Office Equipment & Supplies
Constantly getting paper jams
where the paper comes out there is a rubber roller that roller must be cleaned to get to that roller open the back cover then you will see the fuser cover that cover just drops down then you will see a white plastic remove that plastic by removing two screws at each side of the white plastic you do not have to open the rear part completely that white plastic sould come out if you wiggle it a bit you will have to take it out one side at a time then when that white plastic is removed you will see the rubber roller just clean that roller with benzine or alcohol. The machine gives you paperjams because that roller gets sticky over time.
Oct 29, 2009 | Brother IntelliFax-2820 Laser Fax
All of the sudden, constant paper jams & no paper signal when ful
You can clean them from the rear access/jam cover. Just be careful when turning the rollers, must be slow and smooth movement.
Aug 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
Entire paper stack jammed at feed chute entrance.
check at the rear part of your printer there a backdoor latch there..
open it..and you can get the jammed paper easily..
if there is a pieces of paper left..you can get it by force..
rid the paper into pieces and clean the rollers of your printer..
and restart you printer..
hope it helps..
May 24, 2009 | Epson Stylus CX5400 All-In-One InkJet...
HP Officejet Pro L7780 constantly gives false"paper jam" error
Step 1:
The rollers should be cleaned if the paper fails to feed smoothly into the unit. All document and media rollers should be cleaned using a lint-free cloth lightly moistened with water.
1. The unit must be powered down and the power cord unplugged before cleaning the rollers. This will allow the rollers to be turned by hand in most cases. The paper should also be removed before cleaning the rollers.
2. Remove the rear access door to access the rollers. Clean any dust and debris from the rollers.
3. Open the unit and check the four small metal paper rollers (not the rubber rollers) in the interior of the unit. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the unit and reattach the rear access door.
5. Plug the power cord back in and power the unit up. It should reinitialize for about 20 seconds.
6. Print another extended self-test page.
Step 2:
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+) instead of #.
==== Semi Full Reset ====
Press and hold # and 6 button on the unit while plugging in the power cord.
NOTE: For models that are not fax capable, press plus (+) instead of #.
==== NVM RAM Reset ====
Press and hold OK and Cancel button while plugging in the power cord
May 19, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
ADF (automatic document feeder) constantly jams
change paper pick-up roller & paper stop roller in ADF
Oct 30, 2008 | Brother MFC-8840D All-In-One Laser Printer
Xerox 416 Work Centre Pro Paper Jam
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
Sep 23, 2008 | Office Equipment & Supplies
Brother MFC-9420CN Paper Jam B!!!
open and check for paper in the back. sometimes a corner may have been caught in there and will give you the error.
jb
Oct 25, 2007 | Brother MFC-9420CN All-In-One Laser...
Dell 1700 often jams in one spot
Just in case you don't know where the rollers are in the paper cassette...remove the paper cassette drawer and he rollers are at the top of the entrance to the drawer. There are two rollers, grasp one between your fingers and gentle pull the roller down to see the mechanism better. Rotate both rollers and you may find a build up of dirt/grime on either or both. Simple clean them with an appropriate wet cleaner & lint free cloth.
Mar 04, 2007 | Dell 1700n Laser Printer
Ricoh Aficio  SPC210SF All-In-One Laser Printer Logo
243 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
