Tried connecting laptop to Tv not supported format comes up HDMI connection
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 128 Answers
Check if you are using the correct HDMI cables
Posted on May 13, 2010
Emerson hdmi not working
Double check to see if your TV can support the resolution that your laptop is using. You can try reducing the resolution on your laptop to one supported by your TV.
If the laptop is configured to use the HDMI port as a second (in Windows 7, you can configure multi-monitor support in the display preferences) you will need to adjust the resolution for that monitor.
Failing that, try rebooting your laptop with the TV plugged in - I have found in some cases that this helps the system to propery detect a new display.
Dec 16, 2013 | Televison & Video
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
I tried connecting HDMI cable from laptop to the TV but sound still comes from the laptop and not coming from the tv. And sometimes even the HDMI is connected between laptop and tv monitor is showing that...
Make sure that the proper drivers are installed on our laptop.
If you plan on using an HDMI connection for both Video and Sound, then with the drivers, you should have an HDMI capable sound driver.
If not, then you won't be able to hear sound from the TV, just from the laptop. Check your system specification to make sure that the system is also capable HiDef sound output.
May 12, 2011 | Televison & Video
Ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
Dec 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
How do i connect my acer 5738 laptop to my tv
First of all your TV should support both HDMI and VGA.
If it does lets start with HDMI as you will get audio through the HDMI cable.
Connect the HDMI cable to the TV and set the source on the TV to HDMI using your remote control, connect the other end to the laptop, hold down Fn and hit F5 to toggle between screens.
See if that helps and let me know how you get on.
Good luck
Aug 21, 2009 | Acer Aspire 5720-6661 Notebook PC
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
Open Questions:
Televison & Video Logo
603 people viewed this question
Top Televison & Video Experts
