Question about GE Spacemaker JVM1640SJ Microwave Oven
What size bulb does the JVM1871SK04 GE XL 1800 use?
    President:
  • 949 Answers
The bulbs are 40 watt incandescent.
The GE part number is WB36x10003
Posted on May 13, 2010
The lights on the bottom of my microwave will not turn off. This started when I changed the bulbs due to the old ones burning out. Anyone ever heard of this? Thank you.
If you put in higher wattage bulbs than designed, your bulbs may have caused the control device (relay contacts/triac/diac) to permanently fail thus allowing the circuit to always remain energized.
Apr 30, 2015 | GE Profile Spacemaker XL 1800 36"...
How do I replace the light bulb inside the microwave
Usually you have to remove the top cover, then the globe can be changed, cover is held in place by screws, make sure power is off as dangerous high power can harm you, best left to a specialist
Jan 30, 2015 | GE Profile Spacemaker XL 1800 36"...
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE Spacemaker XL 1800 microwave's controls are locked
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Adora Spacemaker XL 1800 is no longer heating the food. What do I need to do to replace the microwave emitting bulb?
may be , the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. it need to be replaced .
Jan 11, 2010 | GE Microwave Ovens
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1871sk04 GE XL 1800 Microwave
PS50009 is the part number for your glass plate that will cost you $60.00, go to partselect.com, simply put the part number... and place an order ....you know what to do next...
cheers pls mark my solution
Nov 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Intertnal light in spacemaker xl 1800
if there is no plate to unscrew in front of the bulb , then the only way it can be changed is to open the microwave
WARNING: HIGH VOLTAGE CAPACITOR INSIDE WILL STILL BE HOLDING HIGH VOLTAGE
if you are not familiar with this then don't attempt the repair!
then you will need a technician
electech
Oct 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
244 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
