Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
In door controls not working
My water, ice, lights and lock controls in the door of my refrigerator have stopped working. I have diagnosed the problem and figure out it's becuase the wires at the bottom of the door have torn apart. (I heard for others where the wires have torn apart within the door, so they needed a new door, WOW ).
I have been able to splice the wires together using tape, and end cap connectors. And all is working. The problem is the cap connectors, because there's not a lot of space, are sticking out from under the grill plate.
I was wondering if there's a way to slice the wires together without the connectors? Does KitchenAid have a part (easy install)? Should I call an electrician, or just leave well enough alone and be satisfied, that I do not have to get a new door?
Thanks
MW
    Scholar:
  • 105 Answers
You asked the right person!
The easiest way (a bit tricky) is to go purchase some heat-shrink tubing (if you have a way to melt the tubing) that is made for the gauge of your wires. find some extra wire of the same gauge for better clearance. Remove the end caps you used (you will need some solder and a soldering iron--very easy to learn with a bit of practice and inexpensive too). Slide the heat-shrink tubing over one end of the non-connected wire. With a bit of solder and a hot soldering iron, repair the connection. Slide the heat-shrink tubing over the connection and heat (if you don't have a hot hair dryer or other heater to melt the heat-shrink, simply patch lightly with electrical tape).
If you don't have enough clearance for electrical tape, use hot glue over the connections (it works very well, is water-proof, and more common) so you don't get a short, then wrap with only one layer of black electrical tape and tuck away.
Posted on Mar 29, 2008
How to change the light bulb in the outside ice/water dispenser
Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
The light on the outside door (where the ice/water dispenser is) won't turn off. It is dimmer than when you hit the 'light' button, but it stays on constantly when the door is shut. The 'light' button works and turns the bulb brighter, but when you turn it off, it just dims and doesn't go out. The light shuts off when the door is open and turns back on when its closed. Model Number MSD2456GEB
Posted by linsdesk on Aug 31, 2011
Aparajita Batabyal
  • 3,513 Answers
Re: The light on the outside door (where the ice/water...
Hi
Reprogramming your refrigerator to only light up when the dispenser is in use saves energy and keepsyour house darker at night. The light is controlled using the buttons above the water dispenser mechanism.Press and hold the "Lock" or "Lock Controls" button for three seconds to activate the controls if they currently are locked.Tap the "Light" button to switch off the light.Press and hold the "Lock" button for another three seconds to lock the controls from further changes. The light now only comes on when the dispenser is active.
If the above procedure won't work then this will be the cause of a faulty switch. This light switch is an integrated part of the dispenser control circuit board. This will require you, or your service tech to replace the entire dispenser/ice maker control board. It will be located just behind the dispenser fascia, mounted on a bracket. the actual light switch circuit is mounted on this board.
Try this procedure:-
Shutdown the unit for five minutes. Simply unplug the unit for this length of time. This will reset the board, and possibly, fix this fault if it is not to severe. If the shutdown dose not correct the switch action, simply replace the dispenser/switch control circuit board.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Jul 25, 2015 | Maytag Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Ge refrigerator ice maker has stopped making ice
The water valve on the back of the refrigerator is bad, one controls water for the ice maker and one controls water for door water
May 11, 2014 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
I just connected the ice maker water line to the unit. The Frig has electrical power and ice is making. My problem is that the controls at the front of the Frig is not working. I cannot dispense the ice...
Without a model number here how they usually operate. The DOOR / LIGHT switch disables water and ice in door functions. I.e. it is not supposed to operate with the door open. If the switch is open... i.e the light is not working door open, (Switch has 2 functions Light and Water / ive in door operation) Then the control panel / water / ice in door will all not work either. It is possible for the light to work while the CP / H2o / Ice do not work. Usually if a door switch fails the light stops working also. It is not always the case.
Try holding to door switch plunger depressed and see if your CP works and water in door work. DO NOT try ice in door as you can damage things.
If you respond with a model number and brand; I will see what I can dig up for you use while troubleshooting your unit. Expect to see parts data also.
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | Refrigerators
The ice/ water machine not working
Hi and welcome to FixYa, I am Kelly
When both the ice and water in door functions stop the problem is usually the door switch. If the door switch fails in the open position the light stays on when the door is closed and water and ice in door do not work. With the door open depress the door switch plunger to see if the comparment light goes off. If it stays on the door switch has failed. If it goes out.. hold the door plunger depressed and have someone try the water in the door. If the water in the door now works the door switch is not getting depressed enough to allow the water and ice in door to work during NORMAL operation. Again usually it requires door switch replacement to correct the problem. The door switch is a 3 terminal switch. One terminal is common, One terminal controls the light, and One terminal controls the water and ice in door functions. The switch retails for less than $10.00
You remove the switch by sliding a thin knife blade along one side of the switch to release the single locking tab. You can use a putty knife also.
Since you did not include a model number I can not help you with parts data.
There is more that can be done if the door switch is ok but I really need the model number to proceed from here. I will help you... Just respond with a COMPLETE model number.
Kelly
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
No power to ice water and light in door
check and see if the lock was accidently put on, it can happen. I don't think your dumb or anything, i've seen it happen to customers before. there is no fuse, and when it all stops at once its usually the lock was turned on, in rare cases there could be a broken wire.??? hope this helps.
May 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
