My 1500 eco comfort heater was moved and now it will not turn on. Why what can I do
  • 821 Answers
Hello,it's either you are having a bad thermostat or probably the fuse controlling the switch is burnt and it has to be replaced.if that is done you will have your eco comfort heater working as normal.
wish you good luck,
take care.
Posted on May 13, 2010
  • cherry1956 May 14, 2010
    where is the fuse at. How can you tell what is wrong
Comfort Zone CZ 1500 A04 CONTINUES TO COME ON
The AO4 is a board used by Earthwise on the Comfort Zone Heater. The reading is the board being used. If the heater just gives that reading it may need to be reset. This can be done by pressing up, down and enter at the same time. If this does not work unplug and try it again. Hope this helps
May 04, 2011 | Comfort Zone CZ1500WC Infra-Red...
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Nov 16, 2010 | Comfort Zone Heating & Cooling
Need manual for serial # E0825340 model CZ 1500 wt
my comfort zone cz1500wt shuts off when turned on code A03 appears on the display
Oct 25, 2010 | Comfort Zone NEW 09 Electric Portable...
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
Ferroli otc settings
this sounds like the boiler is in comfort mode press the eco/comfort button once and eco will be dispalyed on LCD. also check terminal 3 and 4 have no wires on the terminal strip as this is were the OTC is connected to boiler.
May 02, 2010 | Heating & Cooling
How do you change from celcius to farieheit on comfort zone heater
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release.
- VS
Nov 28, 2009 | RTO Comfort Zone Electric Portable Space...
Settings on my CZ 1500
To switch between C and F, hold DOWN and ENTER for three seconds.
( I sell these. )
Mar 11, 2009 | Comfort Zone NEW 09 Electric Portable...
Rheostat vs. Thermostat Temperature Control
yes, it should work. Just ensure your rheostat will handle up to 1500 watts at reasonable settings. A better approach is a 1500 watt pulse-width modulator circuit that draws little power itself. these are available where power tools are sold (like harborfreight.com and known as speed controllers. I use one for a large air fan in my garage.
Nov 04, 2007 | Presto HeatDish Compact Heater
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
